Problem putting rocker arms on head
Old Jan 17, 2011 | 07:36 PM
WhiteyW/AHonda's Avatar
Default Problem putting rocker arms on head
I recently bought a d16z6 block and put my head on from my d15b vtec. i set the cam in and went to put on the rocker arm assembly and it doesn't set on correctly it rocks on the center posts. i tried torquing it down and it binded on the cam so it couldn't rotate i even tried setting on the rocker arm assembly without the cam in and it still wouldn't set in all the way but didn't rock. without torquing the bolts down and only putting body weight onto it would bind the cam down to where i couldn't rotate it? any ideas on what would cause this to happen? i'm completely stumped i checked everything with a level and everything was flat.
Old Jan 17, 2011 | 10:29 PM
N/A's Avatar
N/A
Purpose Built
Default Re: Problem putting rocker arms on head
Your obviously doing something wrong, get someone else overthere to get a set of eyes on it
We can't exactly help you with just looking at your post
johnson3548
Oct 10, 2013 12:11 AM
vfr700f2
11
Aug 31, 2009 07:44 AM
new_climber
Jan 16, 2009 05:27 AM
blackeg
Dec 30, 2003 11:00 AM
91civicEX
Jun 27, 2003 08:16 AM
