spacer size to clear front integra caliper bracket?
Old Jan 17, 2011 | 05:09 PM
Killa Vanilla's Avatar
Default spacer size to clear front integra caliper bracket?
I don't know if this belongs in "Brakes" or "Wheel and Tire", but I'm having some fitment issues with the wheels I just ordered. The inside of the spokes hit the front brake caliper bracket. I asked local shop about grinding it down and they said it'd be too much to be safe. Unless there is a brake solution (they also called Wilwood and said their kits wouldn't solve to problem), they suggested spacers. Would anyone know offhand what size spacer would be needed to clear the caliper bracket? I wanna go as small as possible because the wheels are already wide.
Car is an 01 Integra LS
Old Jan 17, 2011 | 10:16 PM
r.wright's Avatar
Default Re: spacer size to clear front integra caliper bracket?
a way to test it is to mock up your wheel w/metal washers first then measure the thickness so u wont need to buy the wrong sizes. good luck
Old Jan 17, 2011 | 10:49 PM
like just make my own quick spacers? like they could be cardboard?
also, does brake pad thickness play a part in the width of the bracket?
Old Jan 18, 2011 | 08:36 AM
r.wright's Avatar
sorry. i meant to type : metal washers
Old Jan 18, 2011 | 05:14 PM
teg97's Avatar
I would find out the thickness of what spacer you would need and you can buy 3 and 5 mm spacers for like $10 or $15 dollars
Old Jan 18, 2011 | 07:24 PM
sc34dc4's Avatar
Can you spin the wheel and it just kinda hits or is it so much the wheel won't move? You can get universal spacers at any auto parts store. 5mm is the thickest you can go on stock studs. Anything over that you will need extended wheel studs.
Old Jan 18, 2011 | 11:27 PM
just found this thread:
https://honda-tech.com/forums/suspension-brakes-54/wheel-spacers-2735362/
which i think answers my question as far as spacer size. In the future though, shouldn't a big brake kit, or at least a larger rotor (e.g. ITR upgrade) fix the clearance issue?
Old Jan 24, 2011 | 12:47 PM
bump
Colin
Suspension & Brakes
Oct 1, 2012 06:09 AM
Droolin
Jun 2, 2011 09:32 PM
blown_ss
Mar 1, 2011 12:46 PM
k7q
Suspension & Brakes
Mar 8, 2009 09:36 AM
DSPDA3
Jul 11, 2005 12:03 PM
