Fresh built ls/vtec 1.9l (pro2's, ported head, valve job, degreed already)
ls/vtec engine 3000 shipped anywhere in the lower 48 states
Paypal charges me 3% but I will split the cost with the buyer.
You can purchase it instantly by sending $3045 to my paypal @ ek9lsvtec96@yahoo.com
631 357 0721 text me
Bottom end
97' b18b block cleaned, decked, align honed, and cylinders bored/honed
00' ls crank balanced, micropolished and graphite coated
pr4(ls)rods balanced, shotpeened, big ends resized for arp bolts
rsmachine 81.75 pr3 pistons with hastings rings balanced
Z-10 girdle with arp gsr mainstuds
acl bearings
goldeneagle ls/vtec set with 82mm headgasket
gsr arp headstuds
8mm arp rod bolts
Mfactory magnetic drain plug
Cylinder head
00' b16 head (Hot street port and polish, 3 angle valve job done by cccylinderheads.com)
super-tech valvesprings & retainers
super-tech high compression valves
skunk2 pro2 cams
skunk2 cam gears
Valve cover shaved and sprayed wrinkle black with half moon cut outs for cam gears.
Extras
Golden Eagle cam seal
Golden Eagle ls/vtec kit
Gates performance timing belt
oem port installed in the back of the block for catch can setup
new water pump and t belt tensioner (p72)
new oil pump (p72)
Header not included
Bottom end
acl bearings
gsr arp headstuds
8mm arp rod bolts
Cylinder head
skunk2 pro2 cams
skunk2 cam gears
Extras
new oil pump (p72)
Header not included
