Honda CR-V & Element 2WD & 4WD Element & CR-V
04 crv awd roar in right front wheel
Old Jan 17, 2011 | 03:57 AM
h22apwrdcivic's Avatar
Default 04 crv awd roar in right front wheel
i suspect it to be a wheel bearing. but i have one question, with the vehicle totally in the air on stands and the vehicle in drive should all wheels rotate? on mine only the drivers side front and rear wheels spin passenger side are locked. i attempt to rotate them by hand but they take an extreme amount of force to budge.
the passenger side axle looks as if it has been leaking but there is no visible holes or cuts in the boot. it is also right under the oil filter and i figured it was just old oil that had set up on there and then been slung off when driving on down the road.
i have grabbed top and bottom of the right front wheel and moved it violently to see if i can feel any play and there is none. usually whenever ive had a bad bearing to the point you can hear it i feel play.
oh yeah this only happens once you hit 40mph.
any thoughts ideas would be greatly appreciated. i just hate to spend the money on the bearing or the axle and that not be it.
thanks in advance!
Old Jan 17, 2011 | 01:13 PM
MonkeyMagic's Avatar
Default Re: 04 crv awd roar in right front wheel
wheel bearing or seized caliper or bad axle on that front right.
typically both front wheels will spin in the air.
Old Jan 17, 2011 | 02:42 PM
so what could cause neither of wheels on right/passenger side to spin at all on the awd.
Old Jan 25, 2011 | 06:12 PM
s14civic's Avatar
its normal. sometimes all 4 wheels with not spin. not a true awd vehicle. if you hold the side that is spinning still, the other side with start spinning
.BigSexy
39
Sep 10, 2013 02:57 AM
beanbag
Dec 7, 2008 09:30 PM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
truevietluv636
Sep 8, 2007 03:00 PM
ITRDC2R
Jun 1, 2007 05:43 AM
