Honda S2000 Honda S2000
My S2000 started torque steering tonight???? WTF?
Old Jan 16, 2011 | 10:51 PM
darkdc2teg's Avatar
Default My S2000 started torque steering tonight???? WTF?
So I hopped in my car to go to wallmart tonight and started to notice at 60mph or any hwy speed I could roll into the throttle and it would start to walk the back of the car around... I would actually have to correct it with the steering wheel. And when I let off the gas I feel it go back straight where it was. This is very anoying. normally it just picks up solid and straight. Im not shure if it has anything to do with it but earlyer in the day I did do a few doughnuts in an empty parking lot with a buddy. Did I break a mount or somthing that keeps the rear wheels on track or somthing??? there is no knocking or clanking or any noise at all it is just pulling weird when i roll into the throttle while cruzing down the road. This is my first s2k so I figured you guys could point me in the right direction. I plan on fixing this crap like tomarrow ASAP! Control arms? rear end mounts? What can break or go wrong to cause this? I appreciate any help! Thanks guys.
Old Jan 16, 2011 | 10:56 PM
darkdc2teg's Avatar
Default Re: My S2000 started torque steering tonight???? WTF?
If you for sure know what the heck I did please pm me so it will go to my email and I will get it rite away. Thanks!
Old Jan 16, 2011 | 11:03 PM
dagle's Avatar
snap an axle? tire pressure okay for both sides?
Old Jan 16, 2011 | 11:23 PM
darkdc2teg's Avatar
No its deff not an axle problem it still drives to good... and yes the tire press is perfect I checked that first thing. I just put a whole set of g force's on it last week. It torques worse the further down I mash the accelerator and then straightens up so to speak when I let of the gas. Its enough to make your head move in the car. You cant tell at all at low speeds tho... just like 55 mph and up it will do it.
Old Jan 17, 2011 | 12:53 AM
GSRGuy17's Avatar
When mine did that, it was low tire pressure on the right rear. So I don't know what to tell you.
Old Jan 17, 2011 | 06:45 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Check the alignment. Maybe an adjuster slipped when you did the donuts. If you had broken compnents, you'd be hearing/feeling it.
Old Jan 17, 2011 | 08:07 AM
Scott.'s Avatar
maybe you should stop doing donuts.
Old Jan 17, 2011 | 01:30 PM
hatchedeg's Avatar
http://www.s2ki.com/forums/index.php...#entry11783533
Old Jan 17, 2011 | 02:25 PM
wade's Avatar
I think I may know what it is, shoot me a call man, I have no time to talk
Old Jan 17, 2011 | 04:00 PM
Vyndictive's Avatar
When you put your new tires on I assume you got your wheels balanced. So when you did the donuts one of your wheels weights may have come off... though that would be noticeable all of the time. More so when you mashed it though.
This is a real stretch, but it could be a broken belt in the tire. I had that happen and it was really a strange issue. Obvious at some speeds, non existent at times.
I'd inspect your wheels and rotate the tires and see what that does if you can't find anything obvious when you take a look under the car.
Old Jan 17, 2011 | 08:42 PM
darkdc2teg's Avatar
Haha! Maby your not an S2k owner!
Old Jan 17, 2011 | 08:44 PM
darkdc2teg's Avatar
PM sent buddy thanks
Old Jan 17, 2011 | 08:49 PM
darkdc2teg's Avatar
Thanks for the input guys but I woke up this morning and knew immediately what was wrong. I did have a nail in my left rear tire... Went and had it pluged and problem fixed. it really didnt look to off last night but it was sure as hell flat this mornig! lol! thanks again!
Old Jan 17, 2011 | 09:13 PM
dagle's Avatar
SMH, dagle is always right. haha jk, glad it worked out to be a simple fix.
Old Jan 17, 2011 | 10:15 PM
B serious's Avatar
Wheel balancing does not cause a pull. Ever. People get that wrong quite a bit.
A broken belt causes horrendous shaking and pulling at all speeds. You might have had radial pull due to a shifted belt or manufacturing defect.
I knew this was going to be air pressure related. I assumed that the OP checked air pressure AFTER the problem occured. Never assume. Because you make an *******...outta yourself.
Old Jan 18, 2011 | 06:56 PM
slo_hatch's Avatar
yeah when i read it i thought hmm sounds like the same thing that happened to me the other day haha i had a rear tire with like less than 10psi in it. pretty funny how the car drives with a low tire.
Old Jan 25, 2011 | 10:02 AM
95 integra's Avatar
Ive had similiar issues on a 240sx when the camber (maybe toe) adjustment bolt was loose....it went from what youre saying to VERY unstable as it became looser.
Old Jan 25, 2011 | 10:56 AM
Em1LuiSiR's Avatar
soo true lol
glad you found your problem man.
Old Jan 25, 2011 | 03:31 PM
wade's Avatar
mine did this, it was a rear tire starting to give way at the belt. Looked fine on the outside, but not on the inside once demounted
Old Jan 25, 2011 | 07:58 PM
bky's Avatar
bky
The walking is usually caused by a difference in the total spring rate on one side vs. the other. Total spring rate includes the spring, damper, tire flex, wheel deflection, chassis bending, etc. Low tire pressure is often the culprit: most S2000 drivers will notice 2 psi or even 1 psi of difference between rear tires.
ek9+eg6=me
Mar 5, 2013 01:12 PM
em1effekt
Honda S2000
16
Jun 28, 2012 12:20 AM
JDMbiAtcH
Mar 19, 2008 09:14 AM
