Need help! ef 4 door
Soo i bought this civic and it seems the driver front tire has alot of lean on it. I just replaced the upper ball joint on that side thinking it would fix the lean but it still has the lean. i will get pulled to the right tho. i will post of pics soon of what it looks like. any idea on what it is. the car is on cut springs but thats the way i bought it and reason why the other guy said thats why he sold it. Give me ideas on what it can be alignment? rotor? i ran outta idea and dont wanna pour money into stuff that i dont need.
cut springs are going to **** and probably destroying the bushings in the process...why not just replace them with brand name lowering springs...!!!
i already have springs to fix that problem i just wanna know whats actually making it lean because right now its not really safe to drive so i have it sit and drive me accord as dd
If the springs are cut real short. It will cause the wheel to lean in aka negative camber. Buy new shocks or brand name lowering springs like said befor
i would handle the cut springs, its possible that one spring is shorter than the other spring. camber is part of the downs of lowering a car. nothing that cant be fixed. they have ingalls type camber kits, and uca camber kits to fix your problem.
after you get it fixed, get an alignment. toe is what usually causes the car to drive off center.
check to make sure you have matching hubs on your car. the civic and da integra hubs are different lengths so they will affect camber. when I first got my sedan it had one of each lol.
zeroairskter
Jan 17, 2011 12:05 AM
en00be
Jan 3, 2009 02:21 PM
