Si tranny question real quick
Old Sep 24, 2002 | 07:56 AM
USDM 4G VTEC's Avatar
Default Si tranny question real quick
k guys my comp its down and i dont have my info of links (fav) since my comp its on warranty... i bought a tranny from a friend... it was mated on a A6 and its code says PL3 1000... suposely was stock engine and tranny....motor was blown, big hole in block.... its that the Si tranny?? i did a search and the only few links that came some guy said it was the PL3 3000... can anybody verify this before i get off the library....thanxs!
Old Sep 24, 2002 | 08:34 AM
keithv's Avatar
Default Re: Si tranny question real quick (JDM EF9)
https://honda-tech.com/zerothread?id=98181
look at this entire post. mista bone posts a few pics of si tranny housings and the si markings.
Old Sep 24, 2002 | 11:19 AM
ZCivicTurbo's Avatar
PL3-3000 is what I have in my notes as a 90-91 Civic Si Tranny.
Old Sep 25, 2002 | 08:07 AM
Default Re: Si tranny question real quick (breaka_1_9)
thanxs for that but....
the tranny i got came off a A6 wich came off a 90 Si wich just broke a rod.... ... supposely it was a stock engine and tranny wich my buddy got it bc he swaped a LS for that dude... now.. all the post says Si tranny its PL3/3000..... my tranny says PL3/1000...... i am pretty sure its a Si, but i wanna know for sure and clarify all this confusion with codes....thanxs!
Old Sep 26, 2002 | 06:02 AM
ttt
Old Sep 26, 2002 | 07:52 AM
wronghand's Avatar
I know that my 88 ZC and 89 Si trannies both have PL3/3000. Tonight I will try and look at the spare DX tranny and the 90 Si tranny in my car and see what each of those are. I would think that since Honda changed the the bearing in 90 it may have a different code. Just a thought though.
Old Sep 26, 2002 | 07:55 AM
Louie B.'s Avatar
send an IM to mista bone, he's the d-seties tranny man!!!!
I recenty got an "Si" tranny myself that had no "pl3" (just blank up there) and "1000" I'm thinking I may have gotten jipped, but I might just use it as a core to get a freshly rebuilt trans anyway (he wouldn't take my 4-speed as a core)
Old Sep 26, 2002 | 08:20 AM
keithv's Avatar
Default Re: Si tranny question real quick (thumpu77)
the 88 si tranny case has no markings.
pic courtesy of mista bone
Old Sep 26, 2002 | 08:36 AM
Steve91's Avatar
All the EF 5 speeds have the L3 designation on them. The only way to tell an SI from a DX from a HF is to put it in gear and spin the input shaft and while measuring the rotation of the output shaft (diff gear).
If I remember correctly, you put the trans in 4th gear. Spin the input shaft exactly 10 rotations, and the output shaft should rotate 280' for an SI. (Just past 9 0'clock). If in only spins about 250' its a DX. Less, and its an HF.
Old Sep 26, 2002 | 08:10 PM
Louie B.'s Avatar
but doesn't the 88 si tranny have a 21 spline input shaft? mine has a 20 which should make it an 89-91
I'll have to try that method.
Old Sep 27, 2002 | 05:40 AM
keithv's Avatar
yes that is correct about the spline count. hmmmm.
i don't have a dx or hx tranny case to consult. although i am going by my friend's place tonight and he might have one. i'll try to take a look if he has a non-si tranny lying around.
Old Sep 27, 2002 | 08:03 AM
Default Re: Si tranny question real quick (Steve91)
thanxs i am going to try that tonight and let u know.... bc ill be swaping that tranny tomorrow afternoon and i wanna know fo sho....
thanxs a lot bro!
Old Sep 27, 2002 | 07:42 PM
Louie B.'s Avatar
OK I GOT HOSED!!!!!!!!!
The kid swore up and down that the trans I bought from him had twenty splines, so like an idiot I trusted him. I counted today and sure enough..... 21! It's an 88!
I'm betting it's not even an Si, is it?!?
1989civichatch
Jun 9, 2011 11:10 PM
hatch_kidb18b1
Aug 12, 2009 06:01 PM
sohcvtechatch90
Jan 28, 2007 02:44 PM
ShiftSpeed
Oct 12, 2004 11:34 AM
Brownjd
Aug 26, 2004 11:03 AM
