h23 or h22 ef wiring
Old Jan 14, 2011 | 04:43 AM
russ_512's Avatar
Default h23 or h22 ef wiring
im have an h in my ef hatch (non si) and was wonderin if some knows the location of a write up on how to wire this or if anyone would be willin to make me a harness
Old Jan 14, 2011 | 02:58 PM
russ_512's Avatar
Default Re: h23 or h22 ef wiring
nothin?
Old Jan 16, 2011 | 03:25 PM
russ_512's Avatar
bump
Old Jan 16, 2011 | 03:56 PM
dynamoracing87's Avatar
www.rywire.com
They can make you a harness, But all you have to do is extended a few wires for the alternator and convert it to MPFI. Then purchase a jumper harness for the correct obd.
Old Jan 17, 2011 | 09:20 AM
russ_512's Avatar
well that info might just help, i know about rywire and what not but im not trying to drop that much i just started school right now and ready to get this thing runnin it just need to be wired and a couple other small thing all the hard part is done
thanks again
Old Jan 18, 2011 | 11:50 PM
theft24's Avatar
if youve already done the dpfi to mpfi obd1 then its 3 wires
Old Jan 19, 2011 | 12:10 AM
hatchet_honda's Avatar
if your having problems running a few wires perhaps an h swap is a bit much for you?
Old Jan 19, 2011 | 12:14 AM
theft24's Avatar
x2
do stuff on your on, you save alot that could go else where
Old Jan 19, 2011 | 03:53 AM
russ_512's Avatar
the h is in the car it just needs a couple more things done, like wiring and i was wonderin if i was just dpfi to mpfi and extending the wires for the alt.
i have an ls that had to have the wiring done, i let a friend do it and was considering doing it my self or gettin a harness that looks cleaner
Old Jan 19, 2011 | 05:22 AM
theft24's Avatar
then, extend the alt wires, its best if you go to a junk yard and find an accord and cut about 3-4ft of the alt wires off of it to add, then add the wires for the knock sensor, vtec cyl, and vtec pressure, and if its obd0 convert over then 4 wires for the o2
Old Jul 14, 2016 | 06:15 AM
unuselectus's Avatar
Bringing this back from the dead... Does anyone have pictures or a write-up?
miloH
Dec 27, 2013 10:40 PM
ef9bseries
11
Oct 3, 2010 06:29 PM
4g4dcruisin
Aug 24, 2009 11:26 AM
mixmastermatt
Jan 18, 2007 08:10 AM
FleXingMyEK
Nov 22, 2002 12:45 PM
