how much horsepower/torque do my gsr have?
well i have a stock gsr bottom block my head is p & p by portflow,skunk 2 tuner stage 1 cams & skunk2 camsgears,valve and retainer, skunk 2 intake manifold,itr header,2 1/2 piping allway back w/o cat to a buddy club spec 2 axle back and 68mm throttle body.........haven't got it tuned yet but how much horse power will you think i will make off of these parts????.... just curious how much i have right now....thanks please no negative comments im a noob in motor lol
Dyno it, run it down a track and then you have solid numbers. All dynos read different and all motors perform different with the same parts. Honestly who cares about WHP/TQ? Trap speeds do the real talking.
You asked what HP you might have NOW but never stated a basemap. So im presuming your still plugged into a stock p72 ECU (or so) which would mean very little horespower and should not be driven.
Best of luck with your tuning thats always the rewarding bit!
There is no way any of us can give you an accurate answer.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-forum-guidelines-must-read-before-posting-2875316/
Guess my Horsepower Threads
There is no way to accurately answer such a question and it doesn't promote good technical discussion. These are not allowed and will be locked immediately. If your looking for numbers similar to a setup your running search or check the ''Official All Motor Dyno thread''
BMo Tuning
13
Feb 7, 2008 12:42 PM
