Rebuild or maintenance?
So my car is inching towards 124K miles and i was wondering what i should do. Should i rebuild the motor or just stick to basic preventive maintenance? (Timing belt, water pump, valve seals/adjustment) I'm the 3rd owner of the car and its supposedly been babied and well taken care of. But when i drive it, it feels a little "tired" but that could be my imagination. I went from owning an s2k to the R so maybe i'm just not use to the way the car feels yet. I got an estimate for the rebuild and it's pretty expensive so thats why i'm having second thoughts. I was wondering if that money could be better spent on other parts like brake pads, smsp header or even cams. Any feedback would be much appreciated.
how about do a compression and leak down test to see if its healthy..if its healthy then mod it! if its not then rebuild it! i don't see any reason for a rebuild if the motor is healthy
Yeah BlueR also suggested that and you guys are right, i'll run those tests first and see whats up with the motor. Most likely the motor is nice and healthy and i'm just being paranoid.
mileage is somewhat irrelevant.
how much oil you're burning and compression numbers tell the story
a quart every 500 miles and 150psi mean rebuild
a quart every 1500 miles and 200psi mean keep driving
I just checked my oil level and i'm down a quart and a half after only less than 500 miles since last oil change. That doesn't sound good to me, especially since i haven't been driving it hard at all. I'm taking it to the shop this tuesday so hopefully i'll get more answers then. I'll post up my results.
what's the shop suppose to do?
change your pcv, it could be clogged
do your compression test and a leak down
if the numbers are off you have to rebuild or do a jdm itr engine swap
Rings are worn out. A known issue with your mileage.
Who is quoting you how much for a rebuild? Just curious.
If you don't have to do an overbore, then the parts price for a ring job is almost nothing.
So you think if its worn rings that it'd be affordable? Cause i was quoted $700-800 just for changing timing belt and water pump. I would think removing the head and pistons to change rings would cost around $1200 or more. And at that point i might as well pay a few hundred dollars extra and get the whole motor rebuilt.
you should just post prices in the thread so we can ballpark you on them, pm'ing people with them is senseless
that's on the high side for a timing belt change. i do them frequently for half that and it takes literally 2-3hrs
rs might be an alright place to rebuild your engine but remember. a brand damn new engine from acura is about $4000
a jdm engine is 2500
rebuilds have a lot of potential places for problems
top end is one place. lost motion assemblies should be changed. they always get overlooked. guides usually do, they also get overlooked.
RS Machine $2115 - Bore/hone/deck (going os jdm itr pistons), rebuild head, complete oem gasket, balanced, micropolish crank, assembly and reinstall into car. This doesn't include timing belt or water/oil pump so i think it'll be around $2400.
A used jdm engine is a good option but its also a bit sketchy to me. I won't know for sure how many miles are on that engine and how well its been treated. I'd hate to buy it and then run into the same issues.
if they will pull your motor and rebuild what needs to be rebuilt, then check clearances for $2400 that's not bad
you might need new lost motion assemblies in the head as well. that's one of the wear items that often gets overlooked.
jdm engines do have problems just like anything else. the two big ones are
1. unknown mileage
2. 10 year old + gaskets
1. unknown mileage
1. unknown mileage
1. unknown mileage
that's also just the bottom end
P30 pistons are an option but the piston skirts aren't coated. You could use usdm O/S pistons and deck the head and block a bit more, use a thinner head gasket, or flat faced vavles for a bump in compression.
Jdm itr pistons in O/S don't exist anymore. I've checked everywhere. Just a heads up.
So i dropped the car off today at the shop and decided to go with a rebuild for peace of mind. When Dave (owner of RS) and i looked at the engine today we saw a lot of oil underneath the dizzy and near the vtec solenoid. After seeing that and the fact that i'm losing a lot of oil after 500 miles i decided to go for it. I should get the car back this friday, can't wait.
leadtrum
14
Jul 16, 2003 02:09 PM
