Need help fixing strut/shock..a lot of stuff.
You deffinetly need a new upper control arm, shock, maybe even a knuckle and lower control arm.
We need pictures of that, in a well lite area.
EDIT- also airbags.
my concern is the frame rail didnt make it out ok.
EDIT- also airbags.
so is the strut ok? it looked kind of bent when i was looking at it
also, what areas specifically did you want pictures?
and how do i find if my frame rail is ok? i showed the pictures to a self proclaimed "auto body expert" and he claimed that the white sheet metal was crumple zone and the frame was fine, but i'm not sure if i really believe him
strut is bent.not supposed to bend like that. your spring should be okay, it can flex but not 100% sure unless you take it off to see.
need picks of your lower control arm, and the sub frame.
turbo92subaru
Sep 13, 2005 12:25 PM
babyviper97
Jun 12, 2003 05:42 PM
