Sputtering/bogging all of a sudden at 3,000 rpm?
i have a built gsr motor tuned on neptune.. all of a sudden it started bogging out at around 3-4000 rpms. i cant figure out the situation..i replaced the dizzy, same problem. fuel pressure is good. any ideas? thx guys
i'm not sure about these wires you say are good. that's SO common for a leaking wire. look under the hood at night and rev the motor. you may see blue jumping sparks
ill double-check...but from my experience, if this was the issue, it would be a consistant thing, not just at a pecific rpm..
mine does the same thing, stock ls..changed plugs, wires, cap, rotor, fuel filter, ran injector cleaner...bogs slightly at 3k rpm, more when the temps still cold..
bensebold
Jul 30, 2006 09:44 PM
shivic
Jan 4, 2004 04:36 PM
