Grind noise when vtec hits h22
Old Jan 13, 2011 | 09:23 AM
Blue94Accord's Avatar
Default Grind noise when vtec hits h22
H22 motor
I haven't really looked to into it yet but when i go to hit vtec at 5500rpms you can hear this loud grinding noise like a miss shift. Weird *** noise. I havent taken the valve cover off yet thinking maybe something to do with the vtec rocker arms. The ecu says vtec is engaged but i only let it hit for a second cause the noise sounds pretty bad. The motor idles fine and drive good. no noises or anything before vtec. I had the head pressure tested and resurfaced. wonder if anything got messed up during then.
wondering if anyone else has had this problem before?
FIXED
Old Jan 14, 2011 | 09:51 PM
phootbag's Avatar
Default Re: Grind noise when vtec hits h22
Mind sharing the fix?
mortificationrock
Jun 16, 2007 04:10 PM
Cheap Bastard
Jun 25, 2006 05:08 PM
importimage
Apr 16, 2004 05:34 PM
Ideal R
Jul 7, 2002 10:25 AM
