vtec solenoid
i have *heard* that you CAN interchange vtec solenoids from SOHC to DOHC. personally i have swapped a solenoid from the del sol vtec to the b16a1, but both are DOHC motors.
from honda they are like 220 bucks. i'm sure you could get one from a wrecking yard or someone on HT for MUCH cheaper. it is easily removed (3 bolts and 2 clips)..and is roughly the size of a pack of smokes.
yes they are interchangable
the SOHC silenoid from 92-95 is the same as the B16A1 and A3(delsol?)
the actual head of the SOHC is smaller than the B16 but the internal is identical and the mouting is the same
the 96+ SOHC is different and will not fit
SisterFister
59
Jan 15, 2011 08:10 AM
95GSRBOI
10
Sep 13, 2005 01:34 AM
