Code for radio on a 1996 Acura Integra SE
Hi there,
I just bought my son a used 1996 Acura Integra SE last nite and the radio needs a code in order to turn it on! do you need the serial or vin number?
Please let me know.
Thank you.
Please let me know.
Thank you.
Usually the dealer is able to get the code for you if you show them the VIN with proof of ownership (insurance card)...there is a website that pulls the code but you would need to have so much info from the registered owner in their database that it makes it hard.
If the car came with the owner's manual, check the back, sometimes people write their codes there. I also heard that sometimes there is a sticker in the glove box with the code on it...
usually the code is on the side of the glove box. thats where it was on mine. open the glove box and look on the outside left side and there should be a sticker that has your code on it.
yesss good place to look. I always write the code in the owners manual after i get it for the customers.
Hello I just bought my son a 1996 Acura Integra SE. The radio has a code on it which will not allow it to come on. I believe you have decode the radio and the VIN#JH4DC4464TS010536. The number on the radio is: AJ52512211. Can you help us out to decode the radio so it will come on.
Thank you.
Thank you.
Most of the time it is written in the glove box, owners manual, or on the stereo itself. Anytime the batt cables are removed it will need to be changed. If no one has written it anywhere I believe the dealer can get it for you. Call up the local acura dealer and give then the car vin and stereo vin
The dealer can get you the code, in most cases you will need to go to the dealer, [service dept.] with proof of ownership, have the HU pulled so serial # can be seen, try the number before you leave the dealership, it only takes the service dept. a few sec. to get the code so there should be no charge. 94
Edgar Jhosh
Acura TL, RL & ZDX
Jul 17, 2017 05:13 PM
Melikanw3rkit
Acura TSX
Mar 9, 2007 07:13 AM
