o2 sensor ???
i got a 2004 civic si with i/h/e. my question is i changed my front o2 sensor with a new one and got this code p2252. now my qusetion is the 2 white are for heater the green is signal and white ground. right?
Correct.
Is the sensor you are connecting OEM?
If it is not OEM, did you make sure it is a wide range O2 sensor? This is also known as an a/f sensor. See https://honda-tech.com/forums/honda-civic-2001-2005-78/quick-o2-sensor-wiring-question-2878180/
JoshuaVTEC
Sep 17, 2005 10:25 AM
93FastLs
May 9, 2005 03:26 PM
