Honda S2000 Honda S2000
Misfire at Idle - Stumped
Old Jan 11, 2011 | 01:12 PM
Eyal 951's Avatar
Default Misfire at Idle - Stumped
I could really use some help here. My 2001 S2000 has a random misfire at idle. The first code is always 1399, but after a short time I'll have codes for a couple cylinders. Cylinder three (p0303) is consistently the first cylinder to code, but the rest follow until I pull 1399, 0300, 0301, 0302, 0303, 0304.
The misfire happens ONLY at idle, and I get a flashing CEL. Reving the car or pulling away from the light instantly makes the CEL go solid again. The car feels and drives just fine during the entire RPM range, goes into VTEC just fine, however it idles rough.
Here is what I've done so far:
- Replaced MAP with brand new OEM unit
- Switch Coil #3 and #2 (cylinder 2 is often the last to code a misfire) - No change, misfire still started in #3 and #2 is often the last to code
- Ultrasonically cleaned all 4 injectors - car felt slightly smoother, but no change in misfire idle issue.
- Replaced injectors
- Two valve adjustment's
- Cleaned ISV - car felt better, but no change in Misfire issue
- Replaced spark plugs
- Replaced PCV valve
- Replaced timing chain tensioner
I haven't ever mis-shifted or over-reved the car, so I don't expect the issue to be bent valves.
I've read tons of threads on here, most of the suggestions haven't worked or don't seem like my situation.
Anyone have any suggestions on what my next few steps should be, or have had the same issue with a fix?
Thanks so much for the help!
EDIT: Car is completely stock except for 03 ECU.
Old Jan 11, 2011 | 02:07 PM
camoy's Avatar
Default Re: Misfire at Idle - Stumped
What kind of plugs did you use to do the replacement?
And is your car stock?
Old Jan 11, 2011 | 02:23 PM
Eyal 951's Avatar
The recommended oem plugs. PFR7G-11S (stock number 7772)
The car is completely stock aside from 03 ECU. (Added to the original post)
Old Jan 11, 2011 | 03:01 PM
camoy's Avatar
Have you done the MAP sensore "whack" mod yet?
Old Jan 11, 2011 | 03:30 PM
Eyal 951's Avatar
Well I tried that, didn't work, so I bought a brand new one along with that OEM zip-tie update that keeps the clip plugged in.
Old Jan 11, 2011 | 05:51 PM
camoy's Avatar
Did you double check the gap on the plugs or did you just install them. Sorry I need to ask to make sure that all the simple stuff is checked first before going off on a wild goose chase.
Old Jan 12, 2011 | 10:03 AM
Eyal 951's Avatar
I gaped the spark plugs to the OEM spec before installing. (I've actually been through 2 set of new spark plugs) No worries, I appreciate the effort.
Old Jan 12, 2011 | 11:36 AM
camoy's Avatar
Did the problems start when you switched to an 03 ECU? If not how long did it run ok with the 03 ECU?
Old Jan 12, 2011 | 11:52 AM
JulieU's Avatar
Have you done a leakdown test? Also, have you read up in the UTH section on S2KI? There's a wealth of info about this over there.
Old Jan 12, 2011 | 03:57 PM
Eyal 951's Avatar
The problem did not start after switching to the ECU. I think 6 months or more went by before it started.
I haven't done a leakdown test yet. I've read the UTH section (and posted in it twice) as wrell as the sticky thread about misfires on S2ki.
Old Jan 13, 2011 | 12:55 AM
EJAYATE's Avatar
I Deliver
This happened to me exactly as you describe. I had 8 bent valves(4 intake 4 exhaust), worn out exhaust valve guides and bad valve seals.
Good luck I spent about $3500 all said and done.
I have an 00 with under 50k miles
Old Jan 13, 2011 | 05:02 AM
dagle's Avatar
3500$... on what? lol damn.. woulda swapped a new motor in over that or rebuild for performance..
Old Jan 13, 2011 | 05:38 AM
HondaKyle's Avatar
I built my motor for less and the rods cost 800 alone!
Find stock motors all day for 2 grand!
Old Jan 13, 2011 | 03:35 PM
camoy's Avatar
Well if you have done all else then yes I think a leakdown check is in order. Have you ever had a mechanical over rev? If so you could have caused some valve damage.
As for the inidvidual who spent 3500 that was problably taking it to a shop or stealership.
Old Jan 14, 2011 | 11:06 AM
Eyal 951's Avatar
It's at the dealer today for a leakdown, test fuel pressure etc. Leakdown tester is 70+ and this was 115, so it was worth it even though I hate taking the car to others...
Will update when I hear back.
Old Jan 14, 2011 | 05:46 PM
Eyal 951's Avatar
Alright, got the car back. It's a bent valve in Cylinder #3.
I may just swap so if you've got a swap in socal for a good price, let me know!
Old Jan 15, 2011 | 05:45 AM
dagle's Avatar
a bent valve is hardly a call for a new motor lol.. just replace the valves.
but if you do end up buying a replacement block lemme know if you wanna get rid of yours. i'll pick it up to build it
Old Jan 15, 2011 | 12:36 PM
Eyal 951's Avatar
The motor has 166K on it, and I've been driving with a bent valve for a while. It may be a good opportunity/excuse to swap or rebuild.
PM me an offer for the block if you would like.
Old Jan 18, 2011 | 06:41 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
also be sure to check the spark plugs regularly as they tend to unscrew themselves. my S started throwing the same codes. misfire on all cylinders, turns out the plugs did exactly as i described. make sure theyre torqued to 18-22lbft.
blacK_Dc4
Apr 13, 2013 12:13 PM
Eyal 951
Jan 14, 2011 05:46 PM
89crxsi89
Mar 20, 2010 11:39 PM
Ideal
Oct 11, 2005 10:11 PM
