Jacksonracing supercharger grinding noise!!
Old Jan 11, 2011 | 12:38 PM
IV_SHO's Avatar
Default Jacksonracing supercharger grinding noise!!
I have a supercharged b20 in my crv and there's a terrible grinding noise coming from the supercharger.. Don't knw what the problem is can someone help please...
Old Jan 11, 2011 | 01:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Jacksonracing supercharger grinding noise!!
Check the pulley on the alt. bracket! if its loose or doesnt have a washer on both sides it will give a horible grinding sound.
Old Jan 12, 2011 | 08:06 AM
daveb91's Avatar
could be the front drive unit needs rebuilt or the rotors are...self clearancing...
Old Jan 12, 2011 | 08:13 AM
Spawne32's Avatar
bearings/drive snout problem, etc
Old Jan 12, 2011 | 11:14 AM
IV_SHO's Avatar
So how can I fix this problem??? Is there a rebuild kit??? Is it easy to fix myself???
Old Jan 12, 2011 | 11:16 AM
Spawne32's Avatar
first thing you gotta do is pull the supercharger and identify the problem, then i can say what to replace, most of the parts can be readily found, bearings, snout drive parts, etc. The rotor packs however, cannot.
Old Jan 12, 2011 | 05:38 PM
wunfstgsr's Avatar
Loved
Community Favorite
did you check that pulley? why would you guys tell him to tear apart the supercharger? first check the simple things! then go and tear it apart! i had a horrible sound that sounded exactly like a big bolt was being tossed in the blower! as i kept checking i noticed the lower alt pulley on the bracket was loose and did not have a washer on both sides! after i put a washer and tightened it correct the sound went away and was quiet like a mouse! also check the clearence on the snout pulley to you brake booster! mine was very close and would grind on that on turns reverse and hard exceleration, i ended up using a 3.8 snout pulley for more clearence.
Old Jan 12, 2011 | 08:39 PM
Spawne32's Avatar
i would assume that the OP did a visual inspection first before posting the thread....?
phoinex17
Oct 30, 2013 10:53 PM
RICO_
Honda Civic (2006 - 2015)
57
Mar 2, 2011 07:22 AM
B204door
Aug 31, 2007 12:35 PM
BlueIntegraBoy
Aug 19, 2005 03:46 PM
Integra_RS
Apr 10, 2005 08:49 AM
