VSS Wiring
but im getting confused on what to do, im trying to wire the VSS in my 89 ef si. i know that the ylw,wht wire goes to computer and cluster.
but im trying to find out what to do with the the yly/blu wire . i know it goes to acc power. my question is ive read a few time that u can wire it to the fuse box in number 14 and put a 20amp fuse in, but im confused i installed a 94spec itr cluster in last night works great. the wiring i use said to run the ylw/blu wire to the blk/ylw wire on the cluster (will that work)???
thanks for info
thanks for info
the vss is built into the factory 91 cluster it reads off the speedo cable, unless u have a post 91 trans u now have no vss..if this is not the case, please be more specific as to what engine, ecu and trans u are using...obd 0,1,2...?
ok sry thsi is what ive got going on, ive runing b18a1 turbo, ys1 tranny, ive done a cluster swap (94 spec ) jdm itr cluster, its need the vss, im just trying to find out where or what is the best way to run the acc power wire for the vss, i mean can i run it off the cluster, out the fuse box (if the fuse box how and where) really thats the only thing im trying to find out that all that holding me back, ive done a lot of half a*s wire befor in this car and im wanting to do it right for a change. by the way the jdm itr cluter looks great and works great just have to wire the vss
it from hondas tech website u wont be able to get to the link.. jus update adobe reader......www.adobe.com
i used this write-up when putting my DC cluster in my '91 hatch:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/gsr-cluster-pinouts-90-91-crx-pinouts-how-i-need-help-1732102/
Im not 100% sure it's the same for '88-'89s, but its gotta be pretty damn close
good luck
good luck
cool thanks guys, just found out that the vss that ive got doesnt work tested everything, but not getting a 5v plose from it.
but now ive got another problem idk what happened, everything has been working fine on the cluster, but now the only thing that coming on now is the battery light when i turn the key, it doesnt stay on when the cars runing, but idk the tach isnt work, temp, fuel, check engine light doesnt come on, idk what happened maybe a fuse???? idk ive been moving so i havent been able to look at the car if any one has some ideas that could help thanks
Lazysk8r2
Feb 19, 2012 06:51 AM
4LugR
Jan 22, 2011 07:02 PM
USDMSiR
15
Aug 31, 2006 02:07 PM
