94 Accord Half Shaft Problem
Old Jan 11, 2011 | 03:06 AM
NATIVERYDER's Avatar
Icon6 94 Accord Half Shaft Problem [Solved]
Ok im replacing a 5 speed manual trans for a buddy of mine got it all back together except the half shaft is only going halfway in the tranny. Tried tapping it in with a hammer and still no go, the half shaft come out and goes in fine to the old tranny. any help advise would be great!
Old Jan 11, 2011 | 03:24 AM
djkurious's Avatar
Default Re: 94 Accord Half Shaft Problem
Are you referring to the axle?
Old Jan 11, 2011 | 03:37 AM
yes axle half shaft on drivers side
Old Jan 11, 2011 | 04:21 AM
djkurious's Avatar
That ring on the end of the axle is the culprit. I took the ring off and made the circle a little smaller and inserted the axle back in the transmission. I have done this about 5 axle changes on several peoples cars before. Let us know if this works.
Old Jan 11, 2011 | 04:33 AM
im positive there ain't no ring on the axle halfshaft driver side, because there is no grove for a ring.
Old Jan 11, 2011 | 04:35 AM
djkurious's Avatar
The end of the axle that goes into the transmission, examine it again. It should be a ring in a groove at the end. That's what keeps the axle from popping out the transmission when you are driving.
Old Jan 11, 2011 | 04:42 AM
the halfshaft don't need a ring cause three bolts secure the shaft to the engine
Old Jan 11, 2011 | 05:23 AM
djkurious's Avatar
Does you axle look anything like this: http://www.google.com/imgres?imgurl=...t:429,r:18,s:0
Old Jan 11, 2011 | 05:39 AM
like this but the side closest to the bolt holes has a female end, where the cv shaft goes into the halfshaft
http://www.google.com/imgres?imgurl=...:1&um=1&itbs=1
Old Jan 11, 2011 | 05:51 AM
djkurious's Avatar
Ok, I have never replaced that before. I see what you are saying though.
Old Jan 11, 2011 | 10:08 AM
bump
Old Jan 11, 2011 | 04:04 PM
holmesnmanny's Avatar
Just look at the splines. They may be damaged. Given that there is no ring it should go in easy. You can try gently tapping it in with a rubber mallet.
Old Jan 12, 2011 | 12:54 PM
well figured it out i went back to salvage yard and got the one came off the tranny i purchased and it worked fine.
Old Jan 17, 2011 | 04:32 AM
djkurious's Avatar
Thanks for reporting back.
Old Jan 17, 2011 | 09:56 AM
nus_dogg's Avatar
Good that it works now. For future reference, it's called a Intermediate Shaft, so you don't get others confused by saying half shaft then it makes them think that you're talking about an axle.
Old Jan 17, 2011 | 10:37 AM
dansaleen_04's Avatar
this is very true. It is known as the intermediate shaft and should be called by its proper name but at the same time a half shaft is not an axle. We know that our tranny drive axles has 3 portions to it, the axles at the wheels and the intermediate shaft connecting the driver side axle to the tranny.
Old Jan 17, 2011 | 10:41 AM
nus_dogg's Avatar
Yup, some called that intermediate shaft half shaft but to others, it may confused them too and think that they're talking about axles. But its all good.
Cap'N Chronic
Jun 29, 2011 12:54 PM
hectic57
Jun 18, 2008 02:49 PM
jacoop86
Aug 11, 2006 04:07 PM
Burlyirishdude
Apr 23, 2006 10:28 AM
vha27
Nov 17, 2003 07:27 PM
