EF wheel stud questions
Old Jan 11, 2011 | 01:46 AM
blue91EF's Avatar
Icon5 EF wheel stud questions
driving down the road and get a flat go to pop the wheel off and what once was 4 lug was driving 3 lugs & now its a two lug on the front passenger side wheel.
so i want to put new studs in. but i suppose its a hub setup & when i go to do this i have to disassemble the hub and remove the bearing. I DONT WANT TO DO THIS. wont this ruin the bearing without the proper tool?
so im thinking the cars a turn i might as well just get some used hubs and see if i can pick up a bigger front disk. what would be the best setup without dumping a big wad of cash into this.
(plan on doing 4 wheel disc conversion in the next couple of months.)
& i have 15 inch gsr fat fives. im not sure how big of a brake setup i can even put under those rims but chances are the only thing ide be swapping those out for is a set of 15 inch racing wheels anyway.
any help would be... a help.
thanks
Old Jan 11, 2011 | 05:07 AM
jdm0.3's Avatar
Default Re: EF wheel stud questions
Just get your 4 wheel disc conversion from a DA and you will be good.
Old Jan 11, 2011 | 06:04 AM
Jockone's Avatar
You can grind a small flat on the new studs and you should be able to get them in without pulling the hubs.They will hold at least untill you get your new bigger fron set-up
Old Jan 12, 2011 | 03:39 AM
blue91EF's Avatar
bumpidootle for more info
Old Jan 12, 2011 | 04:35 AM
crx_si-r's Avatar
Screw the DA set up, get the brakes off a 90-91 civic EX sedan. They use the exact same brake pads, calipers and rotors as integers but they are used on the same knuckle as what you have now (dimension wise). If you get the integra knuckles they are taller than what you have now.
I did my EX front brakes a couple weeks ago.
Old Jan 12, 2011 | 05:09 AM
AZGS00's Avatar
if you remove the brake caliper and grind a little off the stud you can do it with little drama. or just do the integra brakes like you were talking about earlier, you can do the bearings, ball joints and replace any bad studs in the process.
Old Jan 12, 2011 | 09:29 AM
hatchet_honda's Avatar
x2 for grinding a flat spot on the new wheel stud. itll go right in. i had to do this a lil while ago on a chevy beretta i bought.
Old Jan 12, 2011 | 01:03 PM
Driven's Avatar
this.
also, separating the hub will not damage the bearing, just make sure you repack it.
Old Jan 12, 2011 | 04:01 PM
blue91EF's Avatar
i need a stud. lol
Old Jan 12, 2011 | 05:25 PM
Jockone's Avatar
Originally Posted by blue91EF
i need a stud. lol
What?
Old Jan 12, 2011 | 07:37 PM
i need a stud. lol
lol gayyy..i mean, autozone! they were like 6 bucks for the chevy
Old Jan 13, 2011 | 06:31 AM
AZGS00's Avatar
Originally Posted by Driven
this.
its a sealed bearing with a pressed fit.
Reusing after separating is highly not recommended
Old Jan 13, 2011 | 08:50 AM
Driven's Avatar
not recommended, but it will work.
The inner race will pull out with the hub, but if you don't lose any of the bearings, you could repack and call it a day. this has been proven to work. I have hundreds of track miles on bearings I've resealed.
Although, the BEST method is to just buy near bearings and hubs. they are super cheap (Bearings are $30~; Hubs are $120)... and much better to have fresh/new parts.
Old Jan 13, 2011 | 09:36 AM
maybe REAR hubs but the FRONTS they no longer sell.
Old Jan 13, 2011 | 10:59 AM
Driven's Avatar
you're right... Hondaautomotiveparts.com doesn't show hubs or bearings listed.
But autozone does sell bearings:
http://www.autozone.com/autozone/par.../N-igrvaZ6o23s
Duralast for $35/each
Hubs, however... That kinda sucks that hubs are hard to find now days.
I guess you guys better be super careful with your hubs =X
Old Jan 13, 2011 | 11:55 AM
THE GREEN CRX//'s Avatar
ill keep that in mind
Old Jan 14, 2011 | 12:32 AM
blue91EF's Avatar
this is my dilemma i might try the ole stud grind fixeroni. unless i can find some 90-91 ex front knuckles one a sweet deal.
still gotta find my RTA's and figure out what year is gonna fit inside my gsr fat fives.
i can just use an impact to set the studs in correct?
another question would be Getting them out?
if i gotta grind them to put them in how am i gonna take that out. i dont think an air chisel is a good idea.
Old Jan 14, 2011 | 11:36 AM
Driven's Avatar
this is HIGHLY not recommended. The stud has a knurl on it that keeps it from spinning in the hub. if you round those off without setting them, the stud will just forever spin in the hub... forcing you to either:
1. spot weld the stud in place
2. replace hub
Ask me how I know this
Cut off a portion of the stud on the face of the hub... then hammer out. falls right out.
Old Jan 15, 2011 | 03:40 PM
Jockone's Avatar
Push the stud in as far as you can then put washers over it and get it started in as far as you can with hand tools then you can use an impact gun to pull them all the way in.
As for getting them out if they have snapped then just hit them with a hammer and they will come out.
Old Jan 19, 2011 | 09:38 AM
blue91EF's Avatar
im just getting a new spindle from a junkyard. thank you for the help tho.
another question however....\\
i found a 97 or 98 integra with the bubble eyes i was wondering if i can use the rear discs from that car and if so what parts can i use for the 4 wheel disc conversion?
can i just take the discs off the 97 teggi rears and put them on my stock TA's or do i have to change or modify something else?
if someout could help me asap because my car is currently on jhackstand doing the from spindle so i might as well do it all at once.,
much thanks.
also can i take the MC BB or PV from this integra? do i need this?
Old Jan 19, 2011 | 11:34 AM
slywfbpsi's Avatar
http://fourthgenhatch.net/wheelstud.html
Old Jan 19, 2011 | 06:13 PM
blue91EF's Avatar
great link.
b16_madman
23
Oct 25, 2005 04:46 PM
dreams_of_ek9
Jun 5, 2005 08:08 PM
vtec_lude
Jun 19, 2004 02:21 PM
nEoMuGen
Nov 15, 2003 04:17 PM
performula
Feb 19, 2003 03:08 PM
