Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Idle problem with 03 odyssey
Old Jan 10, 2011 | 04:31 PM
redheadkimie's Avatar
Icon6 Idle problem with 03 odyssey
I have a 03 Odyssey. Lately when I put it in park it the engine will rev from between 1000 and 2000 rpms. it will go up and down. Now when I pull up to stop at a light or sign it will die and then I have to put it in park and it will start back up. Its also not wanting to start. When I turn the key I will have to push the gas and it will start up. All of this comes and goes. Sometimes it does it and sometimes it doesn't. When it first started acting up the engine light came on and so did the tcs light. We got it checked and the code was p0505 idle control malfunction. we want to try to fix it ourselves but have no idea what to look at. any ideas or suggestions would be great.
Thanks.
Old Jan 25, 2011 | 05:31 PM
s14civic's Avatar
Default Re: Idle problem with 03 odyssey
the idle air control valve (iac) is located on the bottom side of the throttle body. also check the p/s pressure switch connector on the high pressure hose and see if the wires are broken
Old Jul 8, 2020 | 12:55 AM
eotterholt's Avatar
S14civic, you mention the P/S pressure switch, I’m having the same issue. I’m not sure where this is.
Old Jul 8, 2020 | 06:49 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Underside of the vehicle, rear of the engine.
Devon M
Sep 28, 2020 06:50 AM
frostykue
Mar 28, 2013 08:29 PM
dustinbs144
Jan 31, 2011 07:18 AM
Touge Tuning
Feb 25, 2009 08:28 AM
Mr si99
May 5, 2005 08:31 PM
