CEL CODE HELP.x5
Installed a 98 b18c1 obd2 into my 93 civic cx. obd1 2 p72 Ecu and 98 gsr harness.
Car is running rich, jolts when i shift.
I am NOT driving the car, just sitting in my driveway.
Over the past month i couldn't figure out what is wrong with the car. Car starts but these appear.
CEL CODES
3 - map sensor - i have switched the throttle sensor plug around with this sensor, bought a new Map sensor and the code is still coming up.
22 - Vtec pressure valve - i do not have vtec currently hooked up yet.
54 - CKF - crank fluctuation sensor - ?????
65 - Secondary o2 sensor (heater wires) - I connected the GSR secondary o2 sensor into my EG. Ran it as follows.
Green wire (signal wire) = D13
White wire (sensor wire) = D14
1 Black wire (heater wire) = A6
1 Black wire (heater wire) = A11
-----As stated on ff-squad.com------
I don't know to try and run one black wire to my battery or where a 12V output is.? I don't know where.
91 - Fuel Tank pressure sensor - This one is new and came up today while checking CEL.
I just need my car back up and running. I don't know what else i can do to get rid of the map sensor and to fix my secondary o2. New problems keep arising and running low on $.
If anyone can help me out.. much appreciated.
CEL CODES
claytonsmith
May 11, 2006 09:43 PM
