Suspension & Brakes Theory, alignment, spring rates....
Got calipers and carriers, what rotors and pads do I need?
Old Jan 10, 2011 | 10:31 AM
NUISANCE's Avatar
Default Got calipers and carriers, what rotors and pads do I need?
I came up on a set of Acura Legend 2 pot calipers and the modified carriers to bolt them onto my 97 Integra. What rotors do I need to complete this set up? I have had good luck with Axis Deluxe pads, do I just oder the ones to match the caliper? Thanks.
Old Jan 10, 2011 | 02:57 PM
roastbeefrichie's Avatar
Default Re: Got calipers and carriers, what rotors and pads do I need?
1. What rotors do I need to complete this set up?
a. prelude VTEC 11" front rotor, re-drilled to 4X100 (specs identical to ITR 11" front rotor)
b. http://www.fastbrakes.com/ 11" front rotors in 4X100
2. I have had good luck with Axis Deluxe pads, do I just oder the ones to match the caliper? Thanks.
all models listed below share the same size brake pad & interchange
97-01 ITR,
all NSX,
97-99 CL V6,
91-95 legend,
96-98 rl,
95-98 tl,
92-94 vigor,
95-02 accord v6,
91-97 accord wagon,
97-01 crv,
95-01 odyssey,
92-96 prelude vtec
& 97-01 prelude
Old Jan 10, 2011 | 04:27 PM
NUISANCE's Avatar
What year Prelude Vtec or are they all the same? I could just redrill them myself.
Old Jan 11, 2011 | 02:35 PM
no they're not all the same; different prelude trims have different rotor sizes
ROTORS
A. Prelude VTEC 11" front rotors, need to be re-drilled to 4X100.
* the 4th gen prelude is in a 4X114 pattern vs the 5th gen prelude, which is 5x114.
i prefer the 4th gen prelude VTEC, the 11" front rotors can be re-drilled cleanly, without overlapping
Originally Posted by Dogginator
OP, there is no way possible to redrill a 4x100 pattern to a 5x114.3 without overlapping at least one hole. This is dangerous. I cringe when people redrill 282mm ITR rotors to a 4x100. (A 4x114.3 can be redrilled to a 4x100 without overlap.)
B. Fastbrakes SpecR Integra/Civic EX/Civic Si 11" Plain rotors for modified ITR 17CL15VN calipers
Product Code: FB DA/DC SPECR 11 INCH ROTORS $47.50 ea
http://www.Fastbrakes.com/product_p/...h%20rotors.htm
* the fastbrakes 11" front rotor in 4X100 saves you the trouble of re-drilling
732xghost
Suspension & Brakes
Sep 14, 2010 08:53 AM
euclid
Mar 28, 2003 04:17 PM
slimbo
Mar 6, 2003 02:19 PM
Petah
Aug 14, 2002 01:47 PM
IN VTEC
Aug 20, 2001 10:21 PM
