52mm itbs ls/vtec help
Hi, I will like to know what is your opinion with this setup,
LS/VTEC
81.5X89
11.5.1 comp
p/p cyl head,
twm 52mm itbs
buddy club spec3+
Those itbs are to big for the engine, and the cams to small?
The engine can lose power?
Any recomendations are welcome.
LS/VTEC
81.5X89
11.5.1 comp
p/p cyl head,
twm 52mm itbs
buddy club spec3+
I can vouch for the buddyclub cams. They suck! they are weak camshafts that may be already fatigued once you recieve them. If you are going to run those cams sell them and buy type r cams. they perform the say but type r camshafts will not break.
The itbs are bigger than you need but i guess they will support future mods.
This motor would do better with something around the 48mm size.
is the port work done specific for ITBs and high rpm?
The volume of the intake runners will be much too large to make any low end or mid range power but for a track only car it might not be too much of a problem.
The cams needs to be matched to the port work and desired rev-range.
more important than matching them to the intake and exhaust.
the intake and exhaust should be decided on after headwork/cams, and should be chosen based on again, desired rev-range, but also expected power.
kenepo_vtec
Jan 18, 2005 06:07 PM
