NO SPARK !!!!!!!
Old Jan 10, 2011 | 08:25 AM
hey man's Avatar
Default NO SPARK !!!!!!!
Ok so let me start off by saying i changed my cap , wires , plugs , my main relay is goood cas my fuel pump primes , im getting fuel cas i can smeelll it when i take my plugs out , i changed my coil with a brandnew one from autozone , my grounds are goood .
my car turns over but i get no spark at all . i tested all 4 cylynders and nutthin ! so i brought one of them voltage testers and i tested to see if my ICM is any goood . the prongs that stick out off the ICM get voltage and it gets voltage , when i tested the actualll ICM i get nuttthin ...... could that be the promblem
Old Jan 10, 2011 | 12:54 PM
PyroProblem's Avatar
Default Re: NO SPARK !!!!!!!
ICM's are a pretty common failure item on Hondas. Thats one of the first things I check in a "no spark" situation.
Pull the plugs and let all the raw fuel clear out.Swap in a known good ICM and retest.
Good luck!
Old Jan 10, 2011 | 01:14 PM
UncleD's Avatar
Proof that people create threads before searching first.
If you look 3 ****ing threads below yours, you will find a 20+ post thread with ideas of trying to solve your exact problem.
Can I mod please????
Old Jan 10, 2011 | 02:28 PM
Its not even the right forum either, LOL
Yeah I probably just should have ignored it like the rest of you but I was feeling helpful...haha
black90.prelude
Feb 10, 2014 04:22 PM
junkyard racer
Jul 15, 2006 07:21 AM
MemphisR1-freak
May 25, 2004 04:53 AM
blackeg
39
Mar 10, 2004 07:17 AM
