Can't shift gear when trans cold????????????
Making this brief as possible. I haven't own this vehicle for a long time. 1994 Honda accord lx 5-speed. It was driving fine until winter decided to come. I just got into the car one day and it didn't want to go into gear. Now if I shove it into gear and drive around it will start loosening up. Sometime if i rev while putting it into gear it works. Almost feels like i'm trying to change gear without steping on the clutch pedal. Things I have already tried:
Bleed the clutch
Change trans fluid w/ Honda genuine fluid
I don't want to go buying parts left to right. When I bleed the clutch it did drive fine for a entire day, but when I let it sit over night. It went back to where I started
a little help here?
Bleed the clutch
a little help here?
I think I found my solution....I try my best to help when I can or discover something..if you know what I mean.
Here the link w/pic just incase someone ever run into the problem I had.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-clutch-master-cylinder-2596523/
arielb1
Dec 12, 2009 01:34 PM
integracura
Apr 18, 2007 11:18 AM
