honda civic 2000 dx motor shakes like hell
Old Jan 9, 2011 | 09:33 PM
honda02dx's Avatar
Default honda civic 2000 dx motor shakes like hell
ok my engine shakes weird with oil and chek engine light on after weird sound it made not a boom sound on the freeway , so i park it on the side of the freeway emergency side and it didnt wanted to turn on till i left it for 30 minutes off but it still the engine was acting weird moving like it had no motor mount but my motor mounts are ok i try and take the car back home made almost untill hella smoke came out my back pipe moffler so much smoke i got scare i though it was on fire , so same as before engine didnt started up untill waited for 30 minutes it strated still engine act move shake weird so tow came for it ok everytime i press on the gas accelerator it owuld be ok engine would stop acting weird untill ill let go at the gas it would like shake a lil wnated to turn off at home i take look at spark pplugs and dark *** hell buy 4 new one put them in and 10 minutes later i took them off and dark lik eother ones they not burn cause i took off the darkness with my finger its like a burn out dust . now mt car wont start i mess with distrubiator and move the time belt lol i think my belt jumo few teeths but what happen to my motor i was going 85 freeway
Old Jan 9, 2011 | 09:37 PM
honda02dx's Avatar
Default Re: honda civic 2000 dx motor shakes like hell
its and 2000 honda civic dx ok how do i turn the time belt to place need pictures if provided but how do i explain my engine acting like it does now and if i burn th engine why did it run for like 30 minutes on freeway after all this happen fine i was going 65
Old Jan 9, 2011 | 10:35 PM
mouab18c1's Avatar
What? LOL it was hard reading but I kind of get the idea.
If your car is not starting you need to check for spark, fuel, and compression.
If you're not getting spark I would check out the ignition coil inside the distributor, check your ecu and main relay as well. Fuel is powered by your ecu so if the ecu checks out fine you should be fine unless your fuel pump took a dump.
I would check the oil level since you said your oil light came on. Also that popping noise that you said it makes seems to me is a misfire. Line your timing back to Top Dead Center just to make sure your timing belt did not jump.
Old Jan 10, 2011 | 07:24 AM
HAMOTORSPORTS's Avatar
I would love to help, but unfortunately I can't understand what you wrote. Please re-write using proper punctuation, spelling, and gramar.
BTW: wrong forum
Old Jan 10, 2011 | 08:30 AM
grumblemarc's Avatar
The Grumpiest
Originally Posted by honda02dx
ok guys i was on freeway going 80 and my engine did a weird sound and felt it move so i stop side way and notice my engine was off it didnt wanted to star notice my oil light was on so i went and bought oil walk 1 hour and half to closes store i put it it started so i try to take it back home back on freeway but my engine would mov alot and shake like something was loose on it i didnt made by 3 mile home it comepltely threw smoke true my back pipe mofler and it shut down from there again it didnt start so i i waited for 30 minutes and it turn on still my engine shook but when i accelerated it seems not ot shake *** it does when not hitting the gas accelerater so i call the tow truck took it home now my car here for a week not turning on i move the timeing belt kus i knotice when i ground the plugs no ellectred white or blue nothing spark so i mess with the timeing belt how to reset the timeing belt pictures would help why does my engine shakes alot?
What? Is English your native language? You posted this in the wrong forum. Hence the lack of replies.
Old Jan 10, 2011 | 08:35 AM
honda02dx's Avatar
it has fuel and oil i to ok other oil out and put in new one whil ei was at it and bought new spark plugs and how do i chek for compression and wherE? the car wants to start but like the time belt wont let it start and yes i did miss with it so now i need help or pics on putting it back on time to re time it
Old Jan 10, 2011 | 08:38 AM
mouab18c1's Avatar
Should have left the Timing belt alone since you have no idea what you're doing. I say take it to a mechanic and save yourself a headache.
Old Jan 10, 2011 | 08:57 AM
honda02dx's Avatar
yeah but i want to learn how to do it im interesting on this kind of stuff incase something happens dont wanna be wasteing money on other ppl doing it they charge 100 dollar here so yeah get my point.
Old Jan 10, 2011 | 09:12 AM
mouab18c1's Avatar
So what have you done since you got the car home?
Explain in detail
Old Jan 10, 2011 | 09:32 AM
honda02dx's Avatar
I TOOK A LOOK AT ANY HOSES NON SEEMS RIP AND CHEK DISTRUBIATOR SEEMS DINE BUT THE MIDDLE THING INSIDE DIDNT SEEM TO TURN AND WHEN I GROUND MY SPARK PLUG THEY DID NOT TRUE A BLUE OR WHITE SPARK BATTERTY CHANGE STILL NO START BUT B 4 ANYTHING I NEED TO RESET MY TIME SO I CAN ATLEAST GET MY CAR TO TURN ON,
Old Jan 10, 2011 | 12:11 PM
Period: a full stop, a punctuation mark indicating the end of a sentence or phrase.
- Wikipedia
Old Jan 10, 2011 | 12:34 PM
honda02dx's Avatar
damn i came here for help fo rmy baby civic not how to learn to type man please help me man how hard is it to tell me hopw to reset time
Old Jan 10, 2011 | 12:37 PM
mouab18c1's Avatar
According to me you have no experience so I would rather have a shop do it. If you mess up it could result in more damage. Search on google
Old Jan 10, 2011 | 02:54 PM
honda02dx's Avatar
ok i use to go work with a mechanic and he was a family friend he owuld take me to help him we done time belt but not for honda that why im aksing .
Old Jan 10, 2011 | 03:20 PM
mouab18c1's Avatar
Search on google for a guideline on how to do a timing belt for your SOHC motor.
No one's going to spoon feed you word for word on how to
Old Jan 10, 2011 | 03:21 PM
The Grumpiest
OMG.
I ask again; is English your native language? Your communication skills are going to stop you from getting the help you need.
Did it start before you messed with it?
Old Jan 10, 2011 | 04:56 PM
mouab18c1's Avatar
If you can raed this, you have a sgtrane mnid, too.
Can you raed this? Olny 55 plepoe out of 100 can. I cdnuolt blveiee
that I cluod aulaclty uesdnatnrd what I was rdanieg. The phaonmneal
pweor of the hmuan mnid, aoccdrnig to a rscheearch at Cmabrigde
Uinervtisy, it dseno't mtaetr in what oerdr the ltteres in a word are, the
olny iproamtnt tihng is that the frsit and last ltteer be in the rghit pclae.
The rset can be a taotl mses and you can still raed it whotuit a pboerlm.
This is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but
the word as a wlohe. Azanmig huh? Yaeh and I awlyas tghuhot slpeling
was ipmorantt! If you can raed this forwrad it
Old Jan 10, 2011 | 05:08 PM
majdi's Avatar
At least used Google translate if you cannot spell correctly, or used auto spell it help more improve English language skill
http://translate.google.com.my/?hl=en&tab=wT#ms|en|
Old Jan 10, 2011 | 07:24 PM
LOL! I actually remember reading this back in High School and thought it was rather interesting.
Bump to the OP, how do you expect us to give you the answer you need if we can't even understand the question???
Old Jan 11, 2011 | 10:45 AM
honda02dx's Avatar
yes i can read it lik eim readin if you had type it normal but what that has to do with this and, yes english is my native language,
Old Jan 11, 2011 | 12:22 PM
mouab18c1's Avatar
Trust me if people have to figure out what you are trying to say they won't help you.
Its annoying reading run on sentences.
Old Jan 11, 2011 | 03:08 PM
honda02dx's Avatar
ok here goes, if any one has a website or any pictures of how to reset the time blet, may they be nice enough to post them here .? thnak you .
Old Jan 11, 2011 | 04:00 PM
The Grumpiest
Old Jan 11, 2011 | 08:46 PM
honda02dx's Avatar
thank you very much, tomorrow should be my first day on setting it again thanks a lot grumblemarc
Old Jan 12, 2011 | 01:01 PM
95civickilla's Avatar
??? what are you trying to say here?
