H/F frankenstein swap!
"g23" as some people call it.
located in or around 757, virginia
pm me for contact and any questions my names mark
f23a1 head and block 120k'ish miles, leaking headgasket but was running. have not taken apart yet. motor did not overheat.
h22a1 head complete with dizzy
obd1h22 harness
obd1 f23 harness
shifter
shifter cables
m2f4 transmission (unknown miles but works)
arp head studs
aem cam gears
stock h22 intake manifold complete
stock f23 intake manifold (missing an injector)
stock exhaust manifold
megan racing exhaust manifold and downpipe
boxes of extra loose parts i have laying around
all you need is
the pistons you want to run or just use these pistons for lower cr.
axles for your car and swap
and of course to put it together however you want to.
this is a very good base to start this build as you have almost every major part needed for a swap.
$1500 or best reasonable offer. remember that everything i have concerning this swap will go with it. priced for lowballers
currently NOT parting out
obd1h22 harness
obd1 f23 harness
shifter
shifter cables
arp head studs
aem cam gears
all you need is
William Leonard
14
Jan 28, 2014 03:48 AM
s2k3_oc08
Aug 8, 2006 09:50 PM
