Error code P0420 after install distributor cap assembly
Old Jan 9, 2011 | 09:27 AM
frk040's Avatar
Icon2 Error code P0420 after install distributor cap assembly
1998 Honda Civic DX
197k miles
Long story not so short: Car stalled out, wouldn't start, had it towed to mechanic. After diag., determined distributor cap assembly faulty, replaced. Car started and ran fine. One day later, check engine light on, brought it back to mech, found error P0420, reset. Mechanic said cranking engine during diagnosis might have fouled catalytic converter, problem should go away - if not, replace cat. Light is on all the time now. Car runs fine, no smells, smooth engine. Does it seem odd that cat should go ONE DAY after repair was made?? Any input greatly appreciated.
Frank
Old Jan 9, 2011 | 09:31 AM
Former User's Avatar
Default Re: Error code P0420 after install distributor cap assembly
Have you reset the ECU to see whether P0420 returns? If so, the original bad distributor likely caused severe misfires that killed the cat. Right now, I would not suspect that anything the mechanic did caused this code.
Old Jan 9, 2011 | 10:44 AM
BryanM.'s Avatar
Resident Gearhead
A persistent P0420 code is extremely common for 96-00 Civics.
I agree with RonJ, I wouldn't point the blame at the mechanic quite yet.
Raw fuel in the exhaust stream will destroy the catalytic converter in no time.
Misfires will allow raw fuel to enter the exhaust stream.
Was the engine misfiring at all before it was fixed?
Old Jan 11, 2011 | 02:34 AM
frk040's Avatar
Thanks for the replies.
1) error code was cleared twice and returned within 24 hours both times
2) I didn't notice any rough idle at all. Like I said, car ran smooth up until failure, and then again after fix. No rough idle, misfires, good accelleration, no shaky steering wheel while stopped at traffic light, etc.
Old Jun 7, 2014 | 06:29 PM
mo13389's Avatar
^^BUMP^^
I have same 98 DX model and just had distributer take dump on me. 50 miles after installing new distributer, CEL displayed same code. Car drives fine like stated above
Old Jun 8, 2014 | 06:32 AM
^Replace your cat. If you have other question, please create your own thread.
Ej8 d16
Jan 23, 2015 01:37 PM
harvinder
Dec 2, 2008 01:45 PM
psycho.chicken
Jul 21, 2006 09:34 AM
EF_LSVtec
Feb 20, 2003 05:46 PM
Brain909
Aug 22, 2001 01:49 PM
