help wipers wont stop working
Old Jan 8, 2011 | 09:34 AM
gnxpro24's Avatar
Default help wipers wont stop working
I changed my dash for the millionth time and when u turn the key to the second click the wipers are on and they wont stop. noticed there was a missing plus in the wiper control housing and thinking I lot it under the dash when I put it in I took the dash off, again, and theres no plug to be found. So pissed off
Old Jan 8, 2011 | 12:26 PM
BiG ChOr!Zo's Avatar
Default Re: help wipers wont stop working
at least your wipers work...mines haven't worked in 1 year already...!!!
Old Jan 8, 2011 | 01:10 PM
CivicSD's Avatar
just drive with your head out the window like ace ventura
Old Jan 8, 2011 | 03:53 PM
gnxpro24's Avatar
well shouldnt there be a plug in that slot? i dont get it. it started when I took the dashboard out
Old Jan 8, 2011 | 06:47 PM
gnxpro24's Avatar
could it be the wiper motor?
Old Jan 8, 2011 | 06:53 PM
if the wiper motor was bad then the wipers wouldn't move...!!!
Old Jan 8, 2011 | 06:56 PM
KINGVEM^^ED6's Avatar
lol
Old Jan 8, 2011 | 07:18 PM
gnxpro24's Avatar
well I was reading that some other ppl had the problem and thats what it was. took it to the dealer and got it fixed.
ne way I connected a wire wrong and it sparked now the wipers dont move at all. swapped out the relay and the fuse didnt break so what could it be?
Old Jan 8, 2011 | 07:23 PM
Clipsed's Avatar
I don't even have windshield wipers on my car... **** em
Old Jan 8, 2011 | 07:25 PM
gnxpro24's Avatar
around here you wouldnt make it with the killer snow and rain
Old Jan 8, 2011 | 09:07 PM
radex7's Avatar
What do you mean no plug to be found? Normally this section of the harness is taped up together in wire loom, and almost impossible to bend, did you modify your main harness?
Besides, if your wipers work constantly, it should be easier to solve then as if they did not work at all. Start looking for short somewhere, check your grounds, and most of all, if you de-pinned the plugs, make sure you pinned them back in their proper locations.
Old Jan 8, 2011 | 09:51 PM
gnxpro24's Avatar
figured it out. after snipping wires that I should have just let alone and browsing the computer I got it. the extra plug is actually for the rear wiper on hatch models according to the service manual. I took the control arm of the other sedan and it worked. So I took apart the arm from my car and there was a piece broken. glued it back together put it back together and it work great. Too bad I already ripped out my dashboard and crap
Old Jan 8, 2011 | 10:49 PM
Clipsed's Avatar
My car doesn't get driven unless its sunny.
HuyenK
Dec 27, 2017 01:31 PM
mstewart
Honda Civic (2001 - 2005)
21
Jul 9, 2014 03:15 PM
notsoslow
Jun 20, 2009 01:23 PM
dc5itracer
14
Oct 26, 2008 01:21 PM
hindsonher
Feb 25, 2007 03:29 PM
