99 civic d16y5 to y8 advice!
hey whats up....so i gotta 99 civic hx.im swapping a y8 head with the y5. i have the head and intake manifold, im also getting a p28 ecu and a obd2 to obd1 conversion harness. im also getting arp head studs and new gaskets for head and i.m. and im getting the ecu chipped and tuned once its on. anything else i need to do for it to run completely normal. any suggestions/comments would be appreciated, and if ur just gunna hate then f$*# off. dont go off topic like eveyone does
remember running a p28 you going to have to swap to a 2 wire iacv as the y5 has a 3 wire iacv. i dont understand why ur using arp head bolts unless ur going turbo and need to torque the head down alil more to avoid head-lift.
either way if u run a P2P ecu ur gonna need a 2 wire iacv as the HX still had 3 wire its not hard to do there are many write ups on it. emissions wise its easier to run obd2 but p28 u can have chipped and tune better
ok cool. ya thtas what i heard. and i read that if i do do obd1 with p28 i have to change my o2 sensor from whatever it is now(5 or 7 wire) to a 4 wire there for i would have to change my wire harness? thats wat he said
RicerBoi16
27
Jan 12, 2019 12:38 PM
D16/z6minime
Aug 30, 2014 03:15 AM
SuperSi
15
Jun 24, 2006 09:57 PM
