prelude fogs burning fuses
Hey guys I just picked up some square prelude fogs for my sedan...I've been doing research and can't find anything on this...I wired them to my corner lights but everytime I turn them on they keep burning the fuse...what could be the problem and does anyone have a solution?? Any help would be awesome
To much current draw on the circuit. They should be wired on There own circuit I belive they requier a realy for those fogs don't quote me on the relay part cuz I'm not 100% sure. But you could always use a higher amp fuse too
this wiring is for a eg but it might work on a ed civic also...!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/eg-foglight-harness-diagram-2526151/
I found this sight awhile back for a friend and it worked for him. This would probably be the best way to wire up your fogs so there on there own circuit. Best of Luck.
http://www.classictruckshop.com/club...h/foglites.htm
First: that is not the proper way to wire up fog lights. Fogs draw several times more current than corner lights.
Second: Even if you put a 30amp fuse in, the wiring isn't rated for the amount of current fog lights draw.
Third: Use a relay, there is a reason why ALL OEMs use relays for headlights and foglights
Fourth: Look up the wiring diagram for correct wiring.
Fifth: Good Luck
Fifth: Good Luck
If you put a bigger fuse in the place of the one that is blowing you will take a chance on burning the wiring harness because it is allowing the circuit to draw to many amps.
i tried connecting the fogs to a seperate switch...but they still wont work...i bought a pre-made wiring kit an extra relay and it came with a switch...i wired everything up and they worked for a bit till i turned them off... heres how i wired it...from the fogs it goes to the relay,then to the switch,then to the batt i used the instructions i got in this thread...for some reason the fuse holder got really hot and melted...but the fuse didnt burnout...do i need a bigger fuse and wire??? the fuse that came with the wiring kit was a 15 amp...i need sugestions on this...i know i need a bigger fuse but what bout wiring...thanks guys
1lude2envy
Dec 4, 2009 04:47 AM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
