Head gasket issue
Old Jan 7, 2011 | 12:29 PM
redright9's Avatar
Default Head gasket issue
Here is what I have, 1995 civic 1.5L, overheated once pretty bad, head gasket blew. Had shop install new one, machined the head, and 500 miles later, blew again. They installed another gasket and has been fine for about 19k miles. Now, engine lost power, bubbles in radiator, emissions sniffers shows hc's in radiator and doesnt run as smooth.. Seems to be another headgasket...THe shop said maybe a cylinder sleeve has warped or something causing them to keep failing...any thoughts?
Old Jan 7, 2011 | 12:32 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Head gasket issue
Maybe they keep re-using head bolts.
Old Jan 7, 2011 | 04:09 PM
Golden Eagle's Avatar
In most cases it's the head or block surface that is not true causing the problem. The head studs should not be reused at all if your boosting at high levels. The studs stretch and can warp under heat and pressure loads.
Old Jan 7, 2011 | 04:50 PM
luvinlife's Avatar
block or head is head is warped. do you know if they checked the block? did they check the head for cracks at all?
Old Jan 7, 2011 | 11:03 PM
redright9's Avatar
Yes, they did resuse the head bolts.. It is a stock engine, no power adders.. The head was machined but I do not know about the block or if they checked for cracks.
Old Jan 8, 2011 | 05:57 AM
luvinlife's Avatar
your block is sleeved?
Old Jan 8, 2011 | 06:30 AM
The Grumpiest
Those studs stretch. Always a good idea to replace them. I've heard where some people torque them down 5lbs more than recommended without issues.
hawaii_boi_808
Jun 20, 2008 09:17 PM
Day-DayC
May 18, 2006 08:51 PM
simplypinoyy
May 20, 2004 11:31 PM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
servion
Mar 7, 2003 08:35 PM
