Head gasket issue
Here is what I have, 1995 civic 1.5L, overheated once pretty bad, head gasket blew. Had shop install new one, machined the head, and 500 miles later, blew again. They installed another gasket and has been fine for about 19k miles. Now, engine lost power, bubbles in radiator, emissions sniffers shows hc's in radiator and doesnt run as smooth.. Seems to be another headgasket...THe shop said maybe a cylinder sleeve has warped or something causing them to keep failing...any thoughts?
Re: Head gasket issue
Maybe they keep re-using head bolts.
In most cases it's the head or block surface that is not true causing the problem. The head studs should not be reused at all if your boosting at high levels. The studs stretch and can warp under heat and pressure loads.
block or head is head is warped. do you know if they checked the block? did they check the head for cracks at all?
Yes, they did resuse the head bolts.. It is a stock engine, no power adders.. The head was machined but I do not know about the block or if they checked for cracks.
Originally Posted by redright9
(Post 44375916)
(Post 44379628)
