Alternator/Battery Light on HELP...
1991 HONDA PRELUDE SI (b20a5 engine) This similar thing is happening to me....when i go from 3.5RPM and higher, my battery light flickers rapidly and my headlights/dashlights/radio/etc flicker from dim to bright and eventually become all togeter dim....i had my alternator replaced a little under a year ago and i took it back to the same garage because i had a warranty. they said that the crankshaft pulley was rubbing into my timing belt cover...i removed the parts it was rubbing on and its still doing the same thing....i also dont understand how at 4RPM and up, a thin peice of plastic you can cut with a knife is holding back my motor....dosent make sense to me at all....
dose anyone know what could be causing this problem???? im taking my car two states away in a week, and i dont want to be stranded!!!
Alexnaderkeith
Sep 10, 2003 08:32 AM
