Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
Good Aero Info
Old Jan 7, 2011 | 08:02 AM
Ponyboy's Avatar
Painting Masterpieces
Default Good Aero Info
Saw this and thought it post-worthy:
Originally Posted by Autospeed
Honda (Acura) NSX
A NSX has achieved a Cd of 0.32 by using a sleek profile. At the front, the nose displaces a very small amount of air, picking it up and instantly achieving attached flow, which "holds on" until the sharply cut rear trailing edge. Cooling air for the rear-mounted engine enters through integrated side scoops that would create a minimal amount of flow disturbance, exiting underneath the car in its low-pressure area. By continuing the rear slope of the bodywork until the trailing edge, the wake created by the car is very small. Without the need to be mounted high, the rear wing is located in the path of laminar flow since there is no area of turbulence behind the rear window. The rear window also tapers in toward the centre of the vehicle to reduce (eliminate?) turbulence.
A very aero-sophisticated car!
http://www.autospeed.com.au/cms/A_107773/article.html
Old Jan 10, 2011 | 11:14 AM
PaladiNSX's Avatar
Default Re: Good Aero Info
This is cool, I wonder what the data says in regards to the taller NSX-R spoiler
Old Jan 13, 2011 | 03:26 AM
Westrock2000's Avatar
There was a pretty good article in (I think) Motortrend sometime maybe 02-03 where they compared to the top speed of the SRT-10 to the Z06. The SRT-10 had like 100 more HP. But the Corvette was almost a full 10th of a percent lower coeffecient of drag (Cd). In the end the Z06 had a better top end speed. It gave a good real world idea of just what aerodynamics could give you.
Interestingly one of the better aero designs is the "Kammback" or sometimes associated with the Shooting Brake. Its given us such wonders as the Ford GT40 and Ferrari Dino, but also more civil cars like the Toyota Prius (and you thought it was shaped like that just to be ugly!)
EDIT: Also there were the great quotes of the various 90's hyper cars where something like the Mclaren F1 GTR could drive upside down at like 160MPH.....now thats aerodynamics! Why this was never demostrated is something congress needs to look into as a crime against humanity
m R g S r
Welding / Fabrication
May 30, 2007 09:06 AM
thinkbrianthink bu
Nov 7, 2002 07:36 AM
