Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 CRV vs California Smog Test
Old Jan 6, 2011 | 11:25 PM
asonoasono's Avatar
Default 1998 CRV vs California Smog Test
Hello, I am having issues getting my 1998 CRV to pass the California Smog Test. It is failing ONLY in one category, the "Idle" section of the HC (PPM) reading. It is measuring at around 190, with a max of 110.
I know next to nothing about cars or engine mechanics, so elaborate and esoteric explanations are nigh useless. Any practical solution for this problem, or advice?
I've read most of the other Emissions related problems (Cat. Converter, o2 sensor, etc), but I thought i'd start a topic in case the CRV has specific known issues or whatnot in regards to the HC/Smog Test world. (Also, it passed Nevada and Georgia tests with flying colors).
Thanks in advance!
(edit/P.S. The mechanic who performed the Smog Test said off-hand that he'd have to guess it was the Catalytic Converter, which he said will run me upwards of 1600-2000$, which is sadly not in my current budget... So i chose to research elsewhere and come up with other potential solutions)
Old Jan 7, 2011 | 09:23 AM
EL Vap133's Avatar
Default Re: 1998 CRV vs California Smog Test
This guy can really help you: https://honda-tech.com/forums/members/thesmogman-999463881/
His name isn't "thesmogman" for no reason!
Old Jan 7, 2011 | 09:44 AM
asonoasono's Avatar
Will attempt to contact, thank you
Old Jan 10, 2011 | 07:06 AM
thesmogman's Avatar
So here is your post!
Have you checked your plug's yet?
eMpAtHy
Jul 26, 2008 10:30 AM
crxtreme27
Jun 12, 2003 04:15 PM
neoburi
May 10, 2003 10:33 AM
hndarcrb18c1
May 4, 2003 08:59 PM
