Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
HKS AFR
Old Jan 6, 2011 | 05:56 PM
DJKAY's Avatar
Default HKS AFR
Hello everyone,
I have a 07 Civic EX with DC Sports Cat, Headers, and a K&N short intake. I am trying to slightly modify my a/f mixture, and I found a controller that is meant for it but I am stuck on which one to purchase.
The HKS AFR: http://www.autocarparts.com/part/1886/0/
However, there are two types: Type:L, and Type:D.
It says to Use w/Air Flow Meter, what does that mean?
and type D says to use with pressure sensor. I am stuck on what to purchase? What do both of those mean?
Thanks!!
Old Jan 9, 2011 | 09:39 PM
sleeper_civic's Avatar
Default Re: HKS AFR
I'm pretty sure those piggy back computers do not work with our ecus. Hondata is where you should be looking.
Old Jan 10, 2011 | 07:17 AM
HAMOTORSPORTS's Avatar
Default Re: HKS AFR
The model for use with flow meter is for vehicles with a mass air flow sensor, the other for models with a manifold pressure sensor. This is a poor way of making fuel adjustments because it simply modifies the air flow signal to the ECU forcing it to read higher in the fuel maps. Unfortunately, in doing so it will also force it to read from a different area of the timing maps which you don't want to do.
Your best option for your car is the Hondata Flashpro. It will allow full adjustment (just incase you do more mods in the future) and comes with many different basemaps you can start with. However, it is a little more expensive ( Retails for $695 )
Old Jan 13, 2011 | 07:31 AM
Willie Mack's Avatar
Default Re: HKS AFR
hondata
Old Jan 13, 2011 | 08:35 AM
DJKAY's Avatar
Default Re: HKS AFR
So would the Hondata work for a 07 Civic EX? I was reading that it is only available for the k20 series.
Old Jan 13, 2011 | 02:03 PM
Default Re: HKS AFR
yes it will work for your EX
http://www.hondata.com/flashpro_civic.html
JsNA99si
48
Jun 7, 2004 04:19 PM
Built B16A
Jun 29, 2003 08:29 AM
freeplay
Nov 16, 2002 05:42 AM
SilverIntegra
Apr 16, 2002 11:32 AM
austrian type-R
Sep 17, 2001 12:41 PM
