Transmission & Drivetrain Gearboxes, Differentials, Clutches
Automatic to Stick ?
Old Jan 6, 2011 | 05:12 PM
Robertico@DFR's Avatar
Default Automatic to Stick ?
Simple question 96 ek 4dr , in the process or making it stick , wich car can i take the parts out of ? or course an ek but how about eg dc da ef ?????
Old Jan 7, 2011 | 07:33 AM
redline1219's Avatar
Default Re: Automatic to Stick ?
you will need to pull all the parts off of a 96-00 civic manual trans. this includes transmission with motor mount, clutch, flywheel, starter (i think), pedal assy, clutch master and slave cyl and clutch lines, shifter and bushings, i think you can use the auto axles, but you definately also need the manual ecu also (or else you will have check engine lights). hope this helps...
Hondakid95
14
Dec 28, 2011 12:01 PM
ricanxplaya
Apr 20, 2011 09:14 PM
hiphop23j
Aug 25, 2010 03:48 PM
93eg2james
Aug 18, 2006 08:55 PM
Campee
Dec 12, 2003 10:23 AM
