Mishimoto Radiator, Fan kits and Hoses offered at B2autodesigns
Hello Guys,
We have some of these available to ship. Which means fast shipping.
Check them out!!!!
Mishimoto Radiators:
Honda Civic X Line Performance Aluminum Radiator 1992-2000
Honda Accord Performance Aluminum Radiator 1994-1997
Honda CRX Performance Aluminum Radiator 1988-1991
Honda Civic Performance Aluminum Radiator 1992-2000
Honda Civic Performance Aluminum Radiator, 2001-2005
Honda Civic SI Performance Aluminum Radiator, 2002-2005
Honda Civic SI Performance Aluminum Radiator, 2006+
Honda Element Performance Aluminum Radiator 2003-2006
Honda S2000 Performance Aluminum Radiator, 2000-2009
Honda S2000 2000-2009 X-Line Performance Aluminum Radiator
Honda Prelude Performance Aluminum Radiator 1992-1996
Honda Prelude Performance Aluminum Radiator 1997-2001
Mishimoto Fan kits:
Honda Accord Performance Aluminum Fan Shroud Kit, 1994-1997
Honda Civic Performance Aluminum Radiator Fan Shroud Kit, 1992-2000
Honda Civic SI Aluminum Fan Shroud Kit, 2006+
Honda CRX Aluminum Fan Shroud Kit, 1988-1991
Honda Prelude Performance Aluminum Fan Shroud Kit, 1997-2001
Honda S2000 Performance Aluminum Fan Shroud Kit, 2000-2009
Mishimoto Hose kits:
Offered in blue, red or black finish:
Honda Accord Silicone Radiator Hose Kit, 1994-1997
Honda Civic Silicone Radiator Hose Kit 1988-1991
Honda Civic Silicone Radiator Hose Kit 1988-1991 B16 Engine
Honda Civic Silicone Heater Hose 1988-1991
Honda Civic Silicone Radiator Hose Kit 1992-2000
Honda Civic Silicone Radiator Hose kit 1992-2000 B16 Engine
Honda Civic Silicone Radiator Hose Kit 2006+ SI
Honda Prelude Silicone Radiator Hose Kit, 1997-2001
Honda S2000 Silicone Radiator Hose Kit, 2000-2009
Racing Thermostat:
The Mishimoto Honda racing thermostats will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
Acura Integra Racing Thermostat, 1990-2001 $54.99 shipped
Acura RSX Racing Thermostat, 2002-2006 $69.99 shipped
Acura Legend Racing Thermostat, 1991-1995 $54.99 shipped
Honda Accord Racing Thermostat, 1990-2002 $54.99 shipped
Honda Civic Racing Thermostat, 1992-2000 $54.99 shipped
Honda Civic SI Racing Thermostat, 2006-2011 $69.99 shipped
Honda CRX Racing Thermostat, 1988-1991 $54.99 shipped
Honda S2000 Racing Thermostat, 2000-2009 $54.99 shipped
Honda Prelude Racing Thermostat, 1992-1996 $54.99 shipped
Mishimoto Liquid Chill Radiator Coolant Additive 4 oz. Bottle $18.99 shipped
Mishimoto's Liquid Chill Coolant Additive can make your motor run up to 30°F cooler than a standard water/coolant mix. This additive evenly lubricates the metals in the motor for cooler temperatures overall even when compared to water alone. The additive is non-corrosive and also prevents future corrosion. Liquid Chill can be mixed before putting new coolant in your car or directly poured into the already used coolant that you are currently running. Liquid Chill is a great addition for any car be it a street or track machine
Please pm us for best pricing:
We offer the full lin up of Mishimoto parts. If you don't see an item listed send me a pm I will qoute you right away.
Thanks
Adrian
Check them out!!!!
Mishimoto Fan kits:
Racing Thermostat:
Thanks
Adrian
Mishimoto Carbon fiber Radiator caps: $47.00 shipped
•Constructed from hand laid carbon fiber
•Fits Most Import Vehicles
•1.3 Bar Pressure Tolerance (19 lbs)
•Fits 31-32mm Fill Necks
Link to order:
http://www.b2autodesigns.com/product...oducts_id=2891
Mishimoto Temperature Gauge 1.3 Bar Radiator Cap Small $59.00 shipped
•Fits most import vehicles.
•1.3 Bar (19lbs) pressure tolerance
•Accurate temperature reading of coolant
•Maximum Temperature Reading: 130C/250F
Link to order:
http://www.b2autodesigns.com/product...oducts_id=2887
Link to order:
Link to order:
NRG Polished oil catch can: $79.95 shipped
Link to order:
http://www.b2autodesigns.com/product...roducts_id=580
Mishimoto carbon fiber catch can $106.00 shipped
Link to order:
http://www.b2autodesigns.com/product...oducts_id=1961
Mishimoto Oil Catch Can - Black $109.00 shipped
Link to order:
http://www.b2autodesigns.com/product...oducts_id=3899
Link to order:
Link to order:
Link to order:
