Suspension & Brakes Theory, alignment, spring rates....
Camber kits all adjustable???
Old Jan 6, 2011 | 02:05 PM
k_lude's Avatar
Default Camber kits all adjustable???
bought the car with a front camber kit owner said its ebay junk but just wondering if all camber kits are adjustable regardless of ebay junk????
Old Jan 6, 2011 | 02:19 PM
Cynical 1's Avatar
Default Re: Camber kits all adjustable???
they should be, as that is the point - to adjust camber...
Old Jan 6, 2011 | 03:27 PM
98civdx's Avatar
Master Detailer
It should be, however I have seen some people refer to OEM type UCA's as camber kits.
They best thing to do is pull the wheel and take a look.
Old Jan 7, 2011 | 07:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
A camber kit by definition means it's "adjustable", to use for adjust camber, since camber is not adjustable from the factory.
I would just take a look and see if they're OEM (or OE-style) upper arms, or if there is some adjustment there. It could be only the bolts holding the upper arm to the car, while the arm itself is still OEM.
But if it really is eBay junk, I would highly suggest picking up new OEM upper arms, with ball joints and bushings included. Trust me, your life will be much better while driving the car with OEM upper arms and new bushings.
And please, whatever you do, please don't refer to the upper control arms as "cambers". I want to punch someone in the face when they refer to the upper control arms with that term.
Old Jan 7, 2011 | 12:23 PM
98civdx's Avatar
Master Detailer
You and me both.
SWAT
14
Aug 22, 2010 08:43 PM
thumper64
Suspension & Brakes
Nov 10, 2009 07:13 AM
thumper64
Nov 8, 2009 02:46 PM
Sumslapper
Suspension & Brakes
Feb 10, 2006 07:36 AM
