What is this harness??
This is a harness that came with my dohc zc obd0 motor. Can you guys tell me if this is indeed for this motor? Will it plug right into my dx wiring?? It looks like some modifications may have been made, so that leads me to believe it's been converted from dpfi-mpfi, but that's really just a guess, I have no idea!!
If this engine harness is a converted dx, i'll be able to save my old dpfi harness for later.
You have there an si engine harness it wont work on your stock dx harness. If you need a conversion harness feel free to pm me as I make them.
i am going to attempt it on my own first. i'll try to take pictures of before and every step of the way. do you have any tips? where do you suggest routing the wires through the firewall at?
I completely unwrap my harnesses, and clean everything up, any wires that need replacing I will replace. The way I do my wiring, only 4 extra wires need to be run to the ECU, 2 for the dizzy and 2 for the injectors. Those get run like stock, and run right through the grommet that the rest of the harness goes through.
Yup, most of the wires on these harnesses are still good, main wires that begin to go bad is those that run under the dizzy like the o2 and reverse switch wiring.
Yes and no. Difficult to tell from the pics you have posted. If it is modified then they did a calm good job of making it look like a stock si harness besides the red loom.
If this was actually on the dohc zc motor then I think it would only need to be modified at the distributor plug. I think the dohc zc has a cam position sensor outside the distributor, this is were it would have to be modified.
In other words, what is different between a dx harness and an si harness connector? Why can't you just put an si harness in place of the dx harness when you're doing a dpfi-mpfi swap?
the difference in si and dx harnesses is the driver shock tower plug. dx have big plug and si has small plug hence the reason why they don't plug in.
also wiring is different.
so if I went to the junkyard and cut off the ecu side of the shock tower plug from an si, I could then use the shock tower plug on my dx harness and make a "conversion plug" that will allow an si engine harness to fit into a dx car, right? I should do that.
I understand that you must also rewire the ecu harness too and run extra wires into the engine compartment.
This is interesting stuff.
ShadowKhaN
16
May 3, 2016 11:12 AM
vtec-adykt
Apr 17, 2008 06:11 PM
