ECU Code P29
Old Jan 6, 2011 | 02:40 AM
scorreia's Avatar
Default ECU Code P29
Hey guys...
i have one question to do...i ask to many people but never found an answer correctly...
Usually i found in engines (b16A2) p30 ecu code or p28....someone told me the difference is in chip...its more fast to process the information of ECU...
now...i have in my car an P29 ECU...i never found the specifications of this ECU or the original engine of them...
the car redline is in 8500rpm like usual and have a HP normal...
thanks
Old Jan 6, 2011 | 03:55 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ECU Code P29
thanks
Someone doesn't know what they are talking about. It's not that kind of computer.
thanks
You should try Googling.
D16A9
(Same as D16A8 but without a catalytic converter)
* Found in:
o 1988-1991 Concerto (UK/Europe)
o 1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
o 1990-1992 Ballade 160i-DOHC (South Africa)
o 1988-1991 Civic 1.6i-16(UK/Europe)
o 1992-1993 Civic GTi (New Zealand)
o 1989-1992 Rover 216/416 GTi (UK/Europe)
o 1992-1995 Civic Si (Japanese, European and Peruvian version)
+ Displacement : 1,598 cc (97 cu in)
+ Bore and Stroke : 75 mm Ũ 90 mm (3.0 in Ũ 3.5 in)
+ Compression : 9.5:1
+ Power : 130-137 hp (96.9 kW, 132 ps) @ 6.800 rpm
+ Torque : 105 ft·lbf (14.5 kg/m, 143 Nm) @ 5700 rpm
+ Valvetrain : 16 valve (4 valves per cylinder)
+ Redline: 7200 rpm
+ Limit: 7250 rpm
+ Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1)
+ ECU Code: PM7 (P29 OBD1)
+ GearBox : <non LSD> (88-91 L3) (LSD 92- 95 S20)
Old Jan 6, 2011 | 04:41 AM
scorreia's Avatar
thanks about the information...
i try search in google, but i donīt believe that my ECU comes in D16 motors....
i say that because D motors redlline,like you show in this information is in 7200rpm and Fuel/Air information is diferente in D16 or B16....i think that if it is possible, mar car works bad but not..my ECU works in a B16a2 engine, without chip and redline is in 8500 rpm (8200 motor)...and car works very well.
someone with some theory?.
thanks...
Old Jan 6, 2011 | 04:58 AM
The Grumpiest
OBD1 202 JDM P29-900/000 Civic D16A ZC DOHC OBD1 ZC
Someone answered your question here as well. http://www.civic-eg.com/viewtopic.ph...74da4e83944a7c
Possibly you don't like the answers you are getting but nothing I've read any where says that redline is 8500.
http://www.superhonda.com/forum/f6/jdm-p29-ecu-89104/
http://www.automotiveforums.com/vbulletin/t750946.html
http://hondaswap.com/ecus-electronic...p29-ecu-72498/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-identify-your-ecu-810101/
http://cb7tuner.com/vbb/showthread.php?t=17007
Old Jan 6, 2011 | 05:21 AM
94EG8's Avatar
Seagull Management
P29 = DOHC OBD1 ZC
Old Jan 6, 2011 | 05:48 AM
scorreia's Avatar
grumblemarc....
yes...you are correct...someone told me this answer in other forum,
but so, explain me how is possible one ECU of a Original D16 engine, works well in a B16...
this is the Principal answer that i was looking for..
thanks
Old Jan 6, 2011 | 05:51 AM
The Grumpiest
Possibly it's been altered. I have no idea what was done to your ECU but if it redlines at 8500 it's not stock.
I don't know what the big deal is anyway. If it redlines to 8.5k and nothing is wrong why are you questioning it? Ever heard the saying about the gift horse?
Old Jan 6, 2011 | 06:02 AM
scorreia's Avatar
its not a problem, but i stay curious, because in portugal, everyone have P28 and P30 ECU in B16 engine...i never see in portugal no one with my ECU...and i talk with some people and never answer me because they donīt know too..
only one person answer to me and say that ECU is the Sir II ECU...
i resolve to ask this in an international forum to see if the answer is the same...
like i told my ECU is not chiped...comes with car when i buy it and i never does anything to ECU...
sorry the persistance.
thanks for answer
Old Jan 24, 2011 | 11:22 AM
dric's Avatar
thanks for answer
Yeah it is not chiped but it can be... i bought that same ecu P29 like two days ago for the purpose of chipping it.
ef_you_again
Mar 17, 2005 11:14 PM
Camshaft
Aug 4, 2004 03:09 PM
didyouhearthat
Feb 8, 2004 08:06 PM
