b20/gsr build need help
Old Jan 5, 2011 | 08:46 PM
93bubble87's Avatar
Icon6 b20/gsr build need help
ok, as usual im reaching out to the honda tech community.
Last night think i bent a valve on cylinder #4 while tuning my nitrous set up. I have a b20b/ Gsr head. I need to rebuild the head and i want everyone OPINION GOOD OR BAD I would like to upgrade to type r internals to match with the cams.. should I use after market valves? Whats the best ones to buy b/c of the b20 valve tap Myth?
At the machine shop - What type of job to i ask for... 3 angle P&P i dont know what the best procedure is to do, I dont want to call them and look like a stupid ricer and they rape me for $$
Also I'm from North New Jersey I need opinions on local machine shops.
Here's my set-up
b20b block - stock
gsr head- sk2 mani, prelude injectors, type R cams, stock valves..ect
Full bolt on's - FPR, Type R pulley/ lightened flywheel, IHE Chipped ecu
ignition- stock
Replies and PM's would be greatly appreciated!!
Old Jan 6, 2011 | 08:53 AM
93bubble87's Avatar
Default Re: b20/gsr build need help
buuuuummmpppppp
Old Jan 6, 2011 | 09:22 AM
mouab18c1's Avatar
I would stick with OEM ITR valves/ Supertech or Crower Dual valvesprings/retainers.
I would also look into building the bottom block for more potential.
Old Jan 6, 2011 | 09:38 AM
DDTECH's Avatar
Research.. study.. your build idea is very common..
Stay off of b20vtec.com.
Old Jan 6, 2011 | 11:09 AM
93bubble87's Avatar
ya x2 with the b20vtec.com
but speed shops keep telling me to go with the supertech valves and oem springs and retainers.. i know they want to make the sale but still
Old Jan 6, 2011 | 11:18 AM
b20vtech's Avatar
does the machine shop know how to port these Honda GSR heads?
do they have custom high performance profile cutters for the valve jobs?
what are the gains customers have seen with thier portwork or valve jobs?
these are very important to know, because if they dont have or know any of the above, then your getting rape for your money.
Old Jan 6, 2011 | 03:22 PM
93bubble87's Avatar
buuuuuummmpppp
Old Jan 10, 2011 | 09:10 AM
93bubble87's Avatar
bummmpppp
Old Jan 10, 2011 | 09:55 AM
4g hatch's Avatar
has the had ever been milled?? with those cams the valves are pretty close to the pistons assuming its a low compression b20!!! maybe you had some contact with the piston on the dope...possible valve float from over reving??
Old Jan 10, 2011 | 10:01 AM
93bubble87's Avatar
you absolutely right .. thats exactly what happened.. gotta pay to play with that stuff. the head is stock never touched. it will get cut, but im looking at which aftermarket/oem combo is best
Old Jan 10, 2011 | 10:27 AM
4g hatch's Avatar
do you mean as far as valve train??
Old Jan 10, 2011 | 10:32 AM
93bubble87's Avatar
yes correct, i keep hearing supertech, but its super expensive.. i like oem also i want to go itr internals but i keep getting negative feedback
Old Jan 10, 2011 | 11:42 AM
4g hatch's Avatar
If it was me I would jus replace tha valves u bent and use tha stock 1,s...for valve train I wouldn't replacw with used stuff and for tha price of new type r stuf u can get supertech springs... Crower cro-moly steel retainers are only 60 bucks!!.....also either grind your valve reliefs a little deeper or get a thicker head gasket for extra insurance.....that's just me though
Old Jan 10, 2011 | 01:24 PM
UncleD's Avatar
If you think Supertech is "super expensive," building a Honda motor probably isn't for you. I would stick to your small block Chevrolet's if a set of good valvetrain for $250 bucks scares you..
Old Jan 11, 2011 | 06:05 AM
N/A's Avatar
N/A
Purpose Built
Its a jersey thing
dc2b20vtec
Jul 11, 2012 04:56 AM
boostedefhatch
14
Mar 8, 2009 10:59 PM
stevieteg
Dec 3, 2008 08:09 PM
lstecrex
Sep 15, 2008 02:53 AM
TriniTech
Nov 3, 2004 01:21 PM
