JB weld on a cracked block?
Old Jan 5, 2011 | 06:48 PM
gsr96cx's Avatar
Default JB weld on a cracked block?
Has anyone ever tried using JB weld on a cracked block where the oil pressure sensor screws into the block? If so, did it work, how long did it last?
Old Jan 5, 2011 | 06:50 PM
habib's Avatar
Default Re: JB weld
Take it to a shop that can do aluminum welding and have it welded, it will save you time money and headaches
wheelmanbg's Avatar
Default Re: JB weld
your block is cracked there? How did that hapen?
Old Jan 5, 2011 | 06:51 PM
wheelmanbg's Avatar
Default Re: JB weld
aluminum??
Old Jan 5, 2011 | 08:48 PM
apexi_rsx's Avatar
Default Re: JB weld on a cracked block?
yes aluminum can be welded and i would recommend this first.. i would not use jb weld on anything that's gonna have pressurized fluids in it.
Old Jan 6, 2011 | 08:38 AM
Red_Army's Avatar
or shakes...
Old Jan 7, 2011 | 12:56 AM
eghatch9295's Avatar
Stancetard Hate Monger
please pm me when you sell this car so I can avoid the hell out of it. never jb weld anything. there is a reason it is dirt cheap (it doesnt do much, especially around pressurized oil).
Old Jan 7, 2011 | 02:47 AM
BryanM.'s Avatar
Resident Gearhead
In this situation, I agree. Not a good idea.
But JB Weld does have it's place and has work well for many peolpe in certain instances.
Old Jan 7, 2011 | 03:25 AM
TwoFaced's Avatar
Don't do it...there's things you can half-***...and things you most definitely shouldn't.
This would be one of those you shouldn't.
Old Jan 7, 2011 | 12:51 PM
KillerChronic's Avatar
*agreed
Old Jan 7, 2011 | 01:48 PM
nothing_shocking's Avatar
This reminds me of my friend using JB to fix his auto timing belt tensioner on his H22A... I lol'd
Old Jan 7, 2011 | 02:17 PM
98civdx's Avatar
Master Detailer
Just have it welded, some I Know had this problem, shop (speedfactory) fixed it for 20 bucks.
JB weld is great, just not in this area.
Old Jan 7, 2011 | 04:02 PM
TwoFaced's Avatar
Wait...so is it cracked around the threads? You're going to need welding and a helicoil if it is...could you post pictures or at least verify if it's cracked at the threads or not?
Old Jan 7, 2011 | 04:53 PM
94EG8's Avatar
Seagull Management
JB weld wont work well here. I've patched up lots of single cylinder briggs & stratton engines with it though after a rod went through the side, always works great, they use splash lubrication though, so no oil pressure.
Old Jan 7, 2011 | 05:03 PM
tonythetuner®'s Avatar
Don't use jb weld there get it fixed right. Don't get me rong jb weld is good but its good for certain things. Not fixing cracked blockes even if it only where the oil press sensor is lol
Old Jan 8, 2011 | 08:23 AM
wheelmanbg's Avatar
I know aluminum can be welded. I don't think his block is aluminum though
Old Jan 8, 2011 | 08:56 AM
Red_Army's Avatar
unless your talking about a non honda engine you'd probably be the only one with a non aluminum block.
Old Jan 8, 2011 | 09:03 AM
Old Jan 8, 2011 | 10:25 AM
mattyfo0z's Avatar
Reminds me of a local kid who also tried JB welding a crack he had in his block...
Old Jan 8, 2011 | 10:35 AM
Mattdg67's Avatar
Honda engine blocks, and heads are Aluminum.
Also I agree with the others, JB weld on and engine is asking for more trouble than its worth. Just get it welded.
Old Jan 8, 2011 | 10:55 AM
89s1's Avatar
jb weld can be used safely on cracked tranny housings, but typically only the dry part of it (the clutch bell housing) same would go here. I wouldn't jb weld it.
Old Jan 8, 2011 | 10:58 AM
LS-turboner's Avatar
if there is nothing broke off in the threaded hole, no need for helicoil. weld it and re-tap it is all.
Old Jan 8, 2011 | 11:51 AM
TwoFaced's Avatar
Yeah that's why I'm waiting for a picture..."slight" cracks in the block are rare...usually it's pretty brutal.
evosix
Jul 27, 2013 07:39 AM
em1 Ziggy
May 12, 2006 11:08 PM
mo0cow
Oct 26, 2005 04:36 AM
highbrid
Oct 14, 2002 08:33 AM
