JB weld on a cracked block?
Has anyone ever tried using JB weld on a cracked block where the oil pressure sensor screws into the block? If so, did it work, how long did it last?
Re: JB weld
Take it to a shop that can do aluminum welding and have it welded, it will save you time money and headaches
Re: JB weld
your block is cracked there? How did that hapen?
Re: JB weld
Originally Posted by habib
(Post 44363168)
Re: JB weld on a cracked block?
yes aluminum can be welded and i would recommend this first.. i would not use jb weld on anything that's gonna have pressurized fluids in it.
or shakes...
please pm me when you sell this car so I can avoid the hell out of it. never jb weld anything. there is a reason it is dirt cheap (it doesnt do much, especially around pressurized oil).
Originally Posted by eghatch9295
(Post 44372954)
But JB Weld does have it's place and has work well for many peolpe in certain instances. |
Don't do it...there's things you can half-ass...and things you most definitely shouldn't.
This would be one of those you shouldn't. |
Originally Posted by TwoFaced
(Post 44373110)
This reminds me of my friend using JB to fix his auto timing belt tensioner on his H22A... I lol'd
Just have it welded, some I Know had this problem, shop (speedfactory) fixed it for 20 bucks.
JB weld is great, just not in this area. |
Wait...so is it cracked around the threads? You're going to need welding and a helicoil if it is...could you post pictures or at least verify if it's cracked at the threads or not?
JB weld wont work well here. I've patched up lots of single cylinder briggs & stratton engines with it though after a rod went through the side, always works great, they use splash lubrication though, so no oil pressure.
Don't use jb weld there get it fixed right. Don't get me rong jb weld is good but its good for certain things. Not fixing cracked blockes even if it only where the oil press sensor is lol
Originally Posted by apexi_rsx
(Post 44364096)
unless your talking about a non honda engine you'd probably be the only one with a non aluminum block.
Originally Posted by wheelmanbg
(Post 44380704)
I know aluminum can be welded. I don't think his block is aluminum though
Reminds me of a local kid who also tried JB welding a crack he had in his block... :ugh:
(Post 44380704)
Also I agree with the others, JB weld on and engine is asking for more trouble than its worth. Just get it welded. |
jb weld can be used safely on cracked tranny housings, but typically only the dry part of it (the clutch bell housing) same would go here. I wouldn't jb weld it.
(Post 44377476)
Yeah that's why I'm waiting for a picture..."slight" cracks in the block are rare...usually it's pretty brutal.
