Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Ichiba Spacers 5mm-25mm offered by B2AutoDesigns
Old Jan 5, 2011 | 02:46 PM
B2AutoDesigns's Avatar
Default Ichiba Spacers 5mm-25mm offered by B2AutoDesigns
Hi Guys
B2 Auto Designs is offering Ichiba Spacer kits in two different verisons.
First is the Standard Spacer with longer studs.
Ichiba Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
All are Sold as one pair (2pcs) with 10pcs of longer studs. (5 lug applications)
Offered in
5mm, 10mm, 15mm
5mm are $69.00 Shipped (one Pair)
10mm are $109.00 Shipped (one Pair)
15mm are $109.00 Shipped (one Pair)
The Second Verison come with the studs already in the Spacer, This kit would require you to take a look at the Wheels you have to make sure that the back pad of the wheel (where the lugs go through) have indentations next to it, allowing the left over factory stud to come through.
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Ichiba V2 15mm, 20mm, and 25mm $115.00 Shipped (one Pair)
4 and 5 lug applications offered
Please check our website for the listings http://www.b2autodesigns.com/index.php?cPath=45_141
Thanks
Adrian
Old Jan 5, 2011 | 08:48 PM
98civdx's Avatar
Master Detailer
Default Re: Ichiba Spacers 5mm-25mm offered by B2AutoDesigns
Pm'd
Old Jan 10, 2011 | 08:05 AM
All PM's Sent
Thanks
Adrian
Old Jan 13, 2011 | 02:45 PM
bump,
Thanks
Adrian
Old Jan 15, 2011 | 04:06 PM
All pm sent back.
Thanks
Adrian
Old Jan 19, 2011 | 10:27 AM
bump,
Adrian
Old Jan 24, 2011 | 11:16 AM
Monday bump
Charles
Old Jan 29, 2011 | 08:54 AM
Lots of great deals on our website.
Thanks
Charles
Old Jan 31, 2011 | 02:36 PM
wannaBjdmca6's Avatar
hi i got some off ur website over the weekend and how long will they take to ship? thanks! btw pretty good deals
Old Feb 3, 2011 | 08:15 PM
Bump
Thanks
Adrian
Old Feb 8, 2011 | 10:23 AM
bump,
In stock ready to ship.
Thanks
Charles
Old Feb 9, 2011 | 01:05 PM
tuan_turbo_dc4's Avatar
pm'd
Old Feb 9, 2011 | 01:38 PM
PM Sent
Thanks
Adrian
Old Feb 12, 2011 | 03:33 PM
Thanks for orders guys. We have in stock ready to ship. Pm me with any questions.
Charles
Old Feb 16, 2011 | 10:18 AM
all pm sent
Thanks
Charles
Old Feb 21, 2011 | 12:21 PM
all pm sent
Thanks
Charles
Old Feb 24, 2011 | 03:58 PM
all pm sent and orders shipped.
Thanks
Charles
Old Feb 28, 2011 | 07:32 PM
all pm sent
Thanks
Charles
Old Mar 8, 2011 | 09:06 AM
bump,
Thanks
Charles
Old Mar 11, 2011 | 08:52 PM
Bump
Thanks
Adrian
Old Mar 17, 2011 | 10:24 AM
all pm sent
Thanks
Charles
Old Mar 22, 2011 | 08:04 PM
Bump
Thanks
Adrian
Old Mar 27, 2011 | 06:17 PM
Sunday bump,
Thanks
Charles
Old Apr 3, 2011 | 03:29 PM
all pm sent
Thanks
Charles
Old Apr 7, 2011 | 06:16 PM
Bump,
Thanks
Charles
