92-95 Greddy Kit on a a6 90 HB Si
email these ppl. http://www.thedropshop.tv/contact.html
nope this kit should be a direct bolt on. the charge piping might need to be changed slightly and the oil pan will need to come off and drilled in a hole for the oil line. if you want to use the blue box that comes with it you have to convert over to OBD1. I would personally go the ODB1 converions route &
get Hondata 2 and tune it.
well not EXACTLY a direct bolt on--you do need to shave the maifold a bit to keep it from hitting the block. http://dmoore.com/crx/turbo.htm -ALOt of info can be found here to get you on your way
kholmes
Nov 13, 2004 12:48 AM
88CiViC_DX
Jun 11, 2004 11:53 PM
