Transmission & Drivetrain Gearboxes, Differentials, Clutches
ordering clutch and flywheel for crx need help
Old Jan 4, 2011 | 06:19 PM
LsVtec08's Avatar
Default ordering clutch and flywheel for crx need help
im have ordering one of the ebay gripforce. http://cgi.ebay.com/ebaymotors/F1-RA...Q5fAccessories
My question is my crx is an 89 with z6 swap with 89 si tranny which clutch i've read is 200mm, the sight says the clucth is 212mm will this matter or does it just have to be 20 spline count. Also i just wanted to make sure the flywheel for the crx will fit the z6.
Old Jan 4, 2011 | 06:59 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: ordering clutch and flywheel for crx need help
it should be fine as long as your clutch and pressure plate match your flywheel. I had a 90-91 d series flywheel and a 88 si tranny so I ordered the 88si clutch to go with my tranny and found that the pressure plate was too small to bolt onto the 8lb flywheel I had so I just ordered a new pp and used the 88 clutch disk.
team2dcrx
11
Sep 2, 2008 11:24 AM
SPOON_BeIgHtEeNsEe
11
Apr 9, 2004 07:10 PM
PaImportTuner
11
Jan 16, 2004 09:49 AM
DsMWookie
Sep 18, 2002 09:49 PM
